Hi all
I was collecting my car from Cheltenham yesterday evening, so I decided on a first outing with the X6200 on G/CE-001
First impressions of the radio:
- Display is good - very visible, even in full sunlight
- Rx seems to be pretty robust and birdie-free on the HF bands
- The S meter under-reads significantly. Signals that are S9+10 on my IC-7300 are S7 on the X6200
- The noise reduction creates some odd squirly noises when there is only noise present
- Tx audio received good reports
- The internal ATU is excellent
- Although the max power is supposedly reduced to 8W (vs 10W on the X6100), as far as I can tell it’s actually peaking 10W on SSB
- Reducing the power to 3W it played very nicely with the 50W mini PA
- It works nicely with FT8CN for FT8, with an OTG adapter. Just use the X6100 config
- It gets pretty warm. Dont operate at more than 12V or it will get very warm
- The internal battery lasts well, but charges very slowly
A short while into the activation a chap turned up with a pot of white emulsion and painted the trig point … I spent more time talking with him than talking on the radio.
Cheers
Rick
