Hello John, my fault and I apologise. I actually wrote everything down right with my pencil and screwed up with the spot. I also manage to do the same sometimes with some SV calls so you are not alone ;-). I will correct my log. Thanks for the summit.
In reply to G6TUH:
Does not matter, Mike. Can always happen in a hurry.
So I myself mixted names etc. Hi.
Good signal from you 2day, hope to hear you from another summit
Thanks, bye
In activators logs I am sometimes recorded as G0 but at the time they repeated my call correctly as G6. ??
Yes you were very good signal as well. I only give true reports! At this end about 70-75W PEP to my SteppIR vertical which I was very worried about because of the high winds here in East Sussex. There was also a lot of snow. I live on a hill and there were big drifts.
I know that when we spoke you were getting wet so I hope you are nice and dry now.
In reply to G3CWI:
Or myself with George GM4COK. In the early days when we were both very active on VHF Aurora CW contacts - a ‘DIT’ of a difference - the number of QSO’s we had to sort out - phew! Thankfully George has been resident in DU land for some years now.
I used to get problems on the Sunday 5 megs net after the news as G8ABB was a regular there: a bit of noise on the channel and “ABB” sounds like “ADD” and vice versa!
