Quickly check worldwide amateur radio band propagation (conditions) with DXMaps
Step 1. Set up DXMaps
- Visit DXMaps: https://www.dxmaps.com
- Select Map
- Select LF - HF
- Select World
- Under, No layer pull-down menu, select: Gray line
- Under, Select options pull-down menu, select:
PSK Reporter, Continents, Labels/roads, Only last 15 min., Hide call sign info - Under Modes/Props, select: Selec.all modes
Step 2. View Propagation
- Select tab for the band you’re interested in, for instance: 80m, 40m, 30m 20m, 17m 15m, 12m, 10m
- For 6m, you’ll need to select: VHF & up
- Next, select: 50MHz
Related Video: WW Band Conditions with PSK Reporter: https://youtu.be/hHoPjKoMI0Y
