Work in progress: 2m Moxon Beam portable foldable
Hello everyone,
I have worked on a little portable 2m Moxon beam with the goal to make it foldable for the backpack. And also for the rare times I do some portable chasing without activation.
First prototype - just using 4mm bamboo sticks - looks promissing to me. VNA looks happy too :wink:
Those sticks will be replaced by glassfibre reinforced rods. Not to worry that humidity changes the antenna properties.
The sticks can be taken out from the center piece and held together with some rubber bands during transport - or store the bundle in a drawing tube for protection.
It consists of 6 parts that are 3D printed in PETG material. I will publish the files when some design changes are done that I noticed now.
Choke made with 6 turns of RG-188 A/U coax.
Antenna wire is the lightweight type from sotabeams.
Weight: 80 grams (0.176 pound) :+1:
Field test pending… hi
Future version todo:
Seal everything with the liquid tape stuff.
Make the BNC connector a bit more robust/protected.
Make a part for vertical mounting (or just use some cable ties)
73 de Joe
Nice project Joe,
My 3 ele yagi is looking a bit battle scared and in need of repairing with a new one.
I have an ender 3 standing by for when the files are available :slight_smile:
Tim
G4YTD
Joe,
Very nice! WK2Y, new to SOTA, and I were just discussing the merits of trying one of the VHF contests from a summit. This would be a big help! Looking forward to the development.
Scott
Thanks a lot for the feedback and interest.
I am curious to test the F/B ratio. Will need to do some tests over bigger distance with low power to see the effect. Or use an inline attenuater in the cable.
Will keep you updated on the progress.
73, Joe
Short teaser update:
Here a video that shows how it folds:
Btw. a Moxon should have about 3.8 dB gain at resonance and forward/backward ratio of about 20-30 dB looking at this page Moxon beam 144 MHz 2-m-band
I have created already a Thingiverse account for sharing :slight_smile:
Joe
Here the updated prototype on thingiverse:
I just asked a friend to print the parts for me so I don’t know if everything fits after the changes.
If you make it please let me know how it turned out.
I have added another 8 mm hole for vertical polarization mounting for 2m FM SOTA contacts.
73 de Joe
Thank you for sharing your hard work Joe!
I am away with the day job just now, but will let you know how I get on with this :slight_smile:
73!
Tim
G4YTD
Quick update:
The solder connection from coax to antenna wire has yesterday failed during demonstration on a club gathering :blush:. Too much bending broke the unflexible core. But better now than on a summit. There is a small extra part included in the thingiverse zip file to stabilize that. Untested.
73 Joe
Hi Joe,
thank you for sharing this. I have build instandly one.
You might consider to move the BNC Connector a bit further out to give enough space for the cable to run throw.
For all other builders the 4mm arms are 382mm long in my case.
SWR is 1.04 at 145.525 very nice.
vy 73 HB9GVC de Thomas
Hello Thomas,
Thanks for sharing your build. I was was thinking on a version with a bit more space to also hold RG58 type cable. I will make a second optional center.
I have already added a 45° angled BNC connctor to allow horizontal and vertical operation. That should help already.
Excellent, the cable tie is just were I figured it should be.
I was wondering if thingiverse sends our notification if I make changes? That would be a nice feature.
73, de Joe
Thanks for sharing Joe. The Moxon is a great design that gives some gain/direction with a smaller footprint when assembled than a Yagi. I built a Moxon for 2m QRP/P a while back where I used aluminium rods. The two elements were separated by short lengths of fibre glass rods and I used electrical connectors to allow it to be quickly assembled without tools. Mine was designed for handheld use and had boom made of PVC conduit. I wrapped the coax round the boom to form a choke.
I like your design better where you have the custom designed centre that will allow mounting on a pole.
Hello Joe, i’m new to this type of antenna and planning to also make one like your foldable version. But i only want to use it for a vertical polarization.
Can you please guide me in choosing what right Thingverse Zip file will i select in order for me to have it 3D print?
By the way, thank you for your time and kind effort sharing your work to us.
73’s
DV9HF
Hi,
I have already put together a file with all required parts listed on Thingiverse:
The “center” part is designed so that it can be installed with horizontal or vertical polarization. Both pores are foreseen already.
It fits well with the 6m glassfibre pole from Decathlon Lakeside-100-travel-6
73 de Joe
Thank you so much Joe for the reply. I’m gonna send you update as soon as i’m done with the project.
