I went over the 1000 chaser point level today, so I just wanted to thank all of the activators I have worked over the last few months. Thanks to you Arizona now has it’s first Shack Sloth, and it looks like two more Arizona Chasers will hit the 1000 point Chaser level in the next week…or sooner!
Arizona is fast becoming a SOTA HOT SPOT (no pun intended…but this is Arizona we are talking about).
Now if I can only get those first 1000 activator points!
In reply to WA7JTM:
Congrats on making Shack Sloth Pete. You’re correct on Arizona becoming a SOTA hot spot. It seems to be generating a lot of QRP type RF these days and ususally has a good path up here into Eastern Kansas.
Thanks for all the SOTA points on your activation and look forward to working you again soon.
In reply to WA7JTM:
Congrats on Shack Sloth Pete, and good luck on working towards Mountain Goat. You had a really nice signal today from W7A/MN-142. All the best. de Scotty KG3W
Congratulations Pete! You always have a good signal to the summits I’m on. Good to switch places and work you on Deem Hills from home this morning, too.
Eric KU6J
Free SOTA Spot Monitor Software + RBNGate FAQ: http://www.ku6j.com
In reply to WA7JTM:
Congrats Pete on becoming a Shack Sloth and way to go with your activating. You’re turning into a regular and with a booming signal into Southwest Indiana.
See you down the log!
