I activated two Summits today June 29th: many the spots are wrong
W7A/MN-138 Shaw Butte…contacts on 20 and 40 meters from 1340 UTC to 1420 UTC. I was not on MN-143. The SOTA map was not working last night, and the W7A association document shows Shaw Butte with the wrong Reference Number.
W7A/AW-060 North Mountain on 20 meters from 1535 UTC to 1630 UTC
BTW, I’m looking at other Maricopa County North peaks (W7A/MN-XXX)and only MN-001 is correct in the W7A reference manual and the online map. It looks like all of the other MN-XXX peaks do not match with the online reference.
I’ve not checked the other regions yet but MN is certainly not matching up and needs to be looked into.
The issue is the ARM has 13 peaks listed in two sections. I’ve gone over the complete list and sent the corrections to Dan, the association manager so he can correct the ARM. I should have caught these before the ARM went out, you can blame me
The peak designator numbers in the following sections have errors in the ARM: MN, GM, PN, YV
You can note your current ARM with the following corrections. Proceed each with W7A/ of course:
online reference.
The online maps (SOTA mapping project) are correct and match the database.
