W7U - Northern areas
This is a two part post. First should information like this be posted in resources like I did for W7U/RI-003 (RI-003 resources) ,W7U/CA-015, and below. Please advise.
Recently there have been many conflicting resources concering trail access in the W7U-CA,BO,NU, and RI areas. Social media, SummitPost and even Alltrails seem to downplay some of the tensions albeit they are usually good resorces. I recently cancelled a planned trip to W7U/BO-012, Gunsight Peak after friends raised concern (see Sheriffs notification below).
Another example: Within the Cache National Forest, there are numerous private land parcels, or “in-holdings,” which include ranches or leased lands. Unforunatly, there seems to be a changing iterpretation of trial usage in some of these areas. Please refer to the map below for details around CA-015. Albiet this is a public peak in a Nationl Forest there may not be a way to access it. Key: Roads marked in Yellow indicate “No Trespassing,” and Red denotes trails or roads blocked with signage. Historically, I’ve been to the top of W7U-ca15 but canceled this trip as well. I didn’t drive the road to the west as it thus I don’t know if it was marked as “NO Tresspassing” See Second map. After analyzing the area’s parcel data, it is likely that a route exists to reach the peak’s parameters for SOTA; however, due to current access tensions, it is not advisable. There is no cellular covage in that area.
As I come across these situations, should they be posted to SOTA reflector and/or individual peak resources? Is this just the homework that each hiker should undertake?
All the best, W7Ike
I’ve been wondering the same thing about a few of the W7U summits. You could end up with some serious charges, jail time, or, who knows, maybe even strafed if attempted. I usually read the SOTA resources when attempting a new summit, so I would appreciate info there. Hope to hear you out there.
73, Jared, N7MAW
That’s the best place to put info. You can set the Restricted access option and link to this thread or write the text on sotadata. Most people probably use sotadata or sotlas for investigating summits and they both show summit resources.
It is a shame about access.
If you go to the summit page (click on the summit designation) you find the summit data. I clicked on W7U/BO-012 that the first poster had cancelled a trip to, and whatever concerns that there might be locally, nobody had bothered to put anything under resources. That space is there for activators to use, providing information for the benefit of later activators, if you experience an access problem then it seems only sesnsible to leave a message about it for the benefit of fellow activators.
