Yesterday I activated Isaacs Ridge VK1/AC-041 for the purpose of promoting VI10SOTA to EU and other Dx chasers.
A big thanks to the chasers who stuck with me and waited patiently while I navigated my way around high powered stations who clearly didn’t hear me. I was pleased to hear one or two EU SOTA chasers backing me up by stating ‘frequency is in use’. In one case a QRO UK station moved 3kHz down only to bleed 5kHz wide
. I changed frequency three times, 14.330, 14.343, 14.320 and finally took refuge close to the band upper limit at 14.345 MHz. I am wondering if I should try a couple of week day activations?
Great to work a handful of VK chasers, John VK6NU, Ian VK5IS, Nigel VK5NIG and John VK4TJ. ![]()
23 SSB QSOs at 10 watts using an Icom IC-705 into a halfwave inverted V dipole at 7 metres above ground level. Isaacs Ridge doesn’t lend itself to a 20m 1/4 wave ground plane. See photos above.
Countries worked: France, Finland, Switzerland, New Zealand, Czech Republic, Poland, Austria, UK, and Germany. Although the current solar cycle is improving each month, the results indicate similarities to 2014 and 2015 where VK activators were working EU chasers at 5 watts.
VI10SOTA log from Isaacs Ridge VK1/AC-041. If you are not listed in the below log, I didn’t hear you!
Edit: I have checked the SOTA data ‘Show Who Chased Me’ records. There is one so-called chaser who did not work me given I went QRT at 0905 UTC and the chaser claims to have worked me at 0916 UTC. Hello!!!
| Time | Callsign | Band | Mode | Notes |
| 07:39 | F4HZR | 14MHz | SSB | Micke s58 r53 |
| 07:41 | OH1MM | 14MHz | SSB | Pasi s58 r55 |
| 07:45 | SA4BLM | 14MHz | SSB | Lars s59 r52 |
| 07:47 | ZL1SKL | 14MHz | SSB | Soren s58 r54 |
| 07:51 | ZL4NVW | 14MHz | SSB | Matt s58 r53 |
| 07:51 | ZL3MR | 14MHz | SSB | John s59 r55 |
| 07:53 | OK2PDT | 14MHz | SSB | Jan s58 r33 |
| 07:54 | VK6NU | 14MHz | SSB | John s55 r55 |
| 07:58 | OE5HWN | 14MHz | SSB | Helmut s55 r33 |
| 08:00 | GW4BML | 14MHz | SSB | Ben s56 r33 |
| 08:03 | VK5IS | 14MHz | SSB | Ian s59 r56 |
| 08:09 | F4WBN | 14MHz | SSB | Chris s59 r56 |
| 08:13 | SP9JKL | 14MHz | SSB | Jerzy s58 r33 |
| 08:14 | DL6MST | 14MHz | SSB | Klaus s58 r51 |
| 08:16 | HB9MKV | 14MHz | SSB | Rudi s58 r51 |
| 08:17 | DJ2MX | 14MHz | SSB | Mario s58 r44 |
| 08:19 | SM5LNE | 14MHz | SSB | Jan s58 r52 |
| 08:24 | OE6RCD | 14MHz | SSB | Roland s58 r31 |
| 08:26 | VK4TJ | 14MHz | SSB | John s56 r51 |
| 08:29 | VK5NIG | 14MHz | SSB | Nigel s58 r55 |
| 08:34 | G4OBK | 14MHz | SSB | Phil s58 r33 |
| 08:38 | SM5LNE | 14MHz | SSB | Jan s55 r44 |
| 08:54 | 2EOVRX | 14MHz | SSB | Craig s55 r31 |
Map courtesy of SOTA Maps
My next outing with VI10SOTA is next Sunday, 12 February from Mt Taylor VK1/AC-037. FYI, I am planning an activation of Mt Ginini VK1/AC-008 (8 points), at 1700m ASL. I will park that activation for March/April 2023.
I look forward to promoting VI10SOTA to EU chasers throughout 2023.
73, Andrew VK1AD
