Hey there! I like combing over the SOTA map and dreaming up summits that I can combine together into one trip or just seeing what’s in my area. As we all know, there’s a problem with looking at a map of all summits: many of them are on private property, which, without express permission, is a no go! So I did some work with QGIS to make this map:
This map shows all Lower 48 States’ summits grouped first by whether or not they are on public land, then by whether or not they have been activated yet, then by their point value. Here’s a closer look:
Small pink circles indicate summits that are not on public land. Larger diamonds indicate unactivated peaks on public land and are color-coded by points. Small squares indicated already activated peaks and are color-coded by difficult as well. The legend allows you to turn on/off each of these categories:
How is it done?
Available online is the US Protected Land Database (PADUS). One of the layers in this database is a polygon covering every bit of federally-owned land - wow! So, after importing PADUS and the SOTA database as a CSV, a scrip runs through ever SOTA point and assigns a value to a field depending on whether or not that summit point lies within a PADUS polygon. Then you can filter/sort by that field! Below is an example of the PADUS polygon:
This makes it super easy to see which summits are accessible on public land and which are not. Of course, it’s not perfect: this QGIS file is working with a snapshot of the SOTA database and the PADUS layer. Any updates to the SOTA database will need to by manually synced. But I think it’s still a useful tool!
-Zach
Looks like a nice project. Some version of the data online so others can inspect summits near them would be good.
Absolutely. I’m experimenting with exporting to formats that more common apps like Google Earth or GAIA GPS can use while still maintaining the filter controls and appearance. Also it should be noted that this is for the US only - maybe there are publicly-accessible land ownership datasets for other countries out there as well that this could be done for!
I did something similar to find all summits within an activation zone for another 'ota scheme. QGIS is pretty good once you figure it out.
It should be possible to do it for at least some of England and Wales (CRoW Access Land is available to download), although it’s probably not necessary here.
For ZL / VK the results of a similar check for public access to SOTA/HEMA with GIS layers from our various national, regional, commonwealth & state datasets has been published on https://ontheair.nz for a few years now (or VK on the Air if you want VK on the map without scrolling to it)
For SOTA it checks for any public land in the DEM-calculted AZ polygon, rather than just the summit location. Colour coding on the map shows which summits have some known public access, and the summit page lists the names of the parks, roads, easements, tracks, etc that access the AZ.
We use PostGIS rather than QGIS (much faster for spatial analysis, using SQL queries that run automatically each time a new summit is imported from or updated from SOTA/HEMA). But otherwise the process is the same.
Suspect a few other countries will have people who have published similar data. Be interesting to hear of any other innovations.
Very handy! When visiting the US, it is sometimes unclear which summits have public access.
Looking forward to the online version.
