Using different calls during activation
I used special call OE20SOTA/p on an activation yesterday. As the usage of the call is well restricted (callsign my be on air only once at a time) I continued working with my homecall at the end of my timeslot.
Despite the fact that this was not a good idea as some chasers just put the call from the sotawatch spot in their log not noticing that the call changed:
When trying to upload the log to the DB with different calls used I found no way to do so.
with adi file “missing entry”, with separate upload “DUPLICATE”
The edit function does not support editing call used.
Any idea how to upload these qsos?
thank you
73 Martin
You can’t. The software only allows a single call for an activation and only one activation of a summit a day.
What I would do is enter all the QSOs using your own call and place a comment on those you had with the special call that you were reall OE20SOTA/p.
Oh, what a pity. Thank you for reply.
I’ll do so but just the other way round, as there were much more qsos using OE20SOTA/p.
mni tks 73 Martin
I had the exact same issue. :frowning:
