Trip to GM/SS, GM/ES and G/SB
21 September 2025: Sunday - Shilhope Law G/SB-006 and Long Crag G/SB-008
Having arrived late the previous evening we slept in, but emerged to find a much better day: the rain had cleared and the sky was blue with just some fluffy clouds. Despite our late start we still hoped to get two summits done, though the ground was likely to be very wet given the previous day’s rain. First up was Shilhope Law G/SB-006, which Martyn had activated before Caroline was licenced (in the days before it was access land and permission was needed to access the summit).
Beyond Alwinton the single track road winds its way up and down along scenic Upper Coquetdale: a lovely area we used to visit a lot before we got into SOTA and have tended to neglect since due to the relatively low density of summits. Part of the way along there were unexpectedly fields with lots of parked cars and camping, with a few cars parked in passing places. Past that we continued much quieter to the Wedder Leap car park. It was a lovely bright sunny day and cameras were soon in action.
Upper Coquetdale
Upper Coquetdale looking towards Shilhope Law
Our late start meant we weren’t walking until 11:45 – over the footbridge for what turned out to be the muddiest part of the walk up to a gate on the other side of the valley. The footpath running along the side of the valley had a variety of fungi before joining a bridleway above Barrowburn. We left the bridleway to ascend on a grassy track which curved back south to ascend to summit – with several stops to take in the views. We reached the white painted trig at 12:35. It is surrounded by a low shelter which didn’t offer much wind protection.
Fungus on ascent Shilhope Law
Ascending Shilhope Law
Shilhope Law G/SB-006 trig
Since it seemed a quiet area, Caroline set up inside the shelter, lashing the VHF antenna to the trig point, while Martyn was on the outside of the shelter with the HF antenna in the low grassy heather. Caroline struggled on VHF – there are larger hills in several directions – getting just two 2m contacts with relatively poor reports. Martyn did better on 60m so after he had qualified with 5 contacts, he handed HF over to Caroline for a run of 13 on 40m, including an S2S with M0LZN on G/NP-028 which Martyn also managed – though he had been having a rag chew on 2m FM with one of Caroline’s earlier contacts. We decided that with lunch eaten we needed to descend if we were going to have time do another hill, but then noticed a 20m spot for OY/WN2G on OY/OY-100, and we could hear him even with the links set to 40m, so a quick change of links and we both had an S2S with the Faroes.
Shilhope Law G/SB-006 VHF
Shilhope Law G/SB-006 HF
Despite trying to keep a good pace it took nearly 45 minutes to descend, partly because we couldn’t resist more photo stops. It had partly clouded over and the forecast included scattered showers, but we stayed dry.
Descending Shilhope Law G/SB-006
Looking back at summit when descending Shilhope Law G/SB-006
Upper Coquetdale when descending Shilhope Law G/SB-006
It was 15:23 before we were leaving the car park. The original hope had been to do Tosson Hill G/SB-007, but we didn’t have enough time for that, so instead went for Long Crag G/SB-008, which was a shorter walk, and looked like the final return section was a track that could be done with head torches. The drive between the two was frustrating. The activities in the fields in Coquetdale now included lots of mountain bikers coming up the valley as well as some vehicles leaving the fields, so there were lots of stops in passing places to allow bikes to pass. Through Alwinton onto slightly wider roads we caught up with a “Chelsea tractor” that appeared not to be used to driving on rural roads, generally driving slowly and taking all corners very carefully! It was a relief when it pulled in in one of the villages, and we were finally parking in the rough layby at NU091072 45 minutes after leaving Wedder Leap.
We had been up Long Crag pre-SOTA, on that occasion doing a longer walk from the Thrunton Wood parking further north, but now needed to minimise distance. We weren’t sure we would have time for an activation, but wanted a walk anyway. We took the forest track opposite the parking, passing quite a few felled areas and under transmission lines before entering a narrower more wooded area, eventually bending round to run near the edge of the forest before emerging onto the open heathland with good views either side. The activation area extends almost to the edge of the forest, but we continued on the gently rising path, over one sub summit with a spot height the same as the trig point and along to the white pointed trig point in a little grassy area.
The ascent had taken 50 minutes and it was gone 5pm: would there be any chasers about? There was no shelter, so Caroline again used the trig point to support the antenna, while Martyn set up HF in the heather nearby. 60m wasn’t in good shape and after Martyn had managed only one contact he asked Caroline how she was getting on – she had two on 2m: David G0EVV and Derek G1ZJQ. Martyn worked David on 2m, and then Derek on 70cms after Caroline had moved there. That was it for VHF and 60m despite further attempts, so we moved to 40m, both working the first two contacts and then Caroline running for 8 contacts. Martyn had needed to use 4 different bands to qualify the hill! While we had been operating, we had seen partial rainbows, but had remained dry throughout.
Long Crag G/SB-008 VHF
Long Crag G/SB-008 HF
Long Crag G/SB-008 HF plus rainbow
Long Crag G/SB-008 rainbow
Long Crag G/SB-008 low sun - time to descend
There was some lovely afternoon light as we packed up and descended, getting good views before entering the forest. Somehow the descent took slightly longer than the ascent, but we had enough light to get back to the car without needing head torches. The car was wet, so the rain hadn’t missed us by much.
22 September 2025: Monday - The Cheviot G/SB-001
We first climbed The Cheviot over 24 years ago, before either of us were licenced, on that occasion the summit came relatively near the end of a 24km route, being a there and back diversion from a circular route around the hill that had taken us along the border ridge. Our reaction at the time was lovely walk but shame about the flat boggy summit, though we could have done without being eaten by midges on our descent by Harthope Burn. Not a summit we intended repeating at the time, but then SOTA came along it became G/SB-001. The Cheviot has a reputation for bogginess, and two days earlier there had been torrential rain, so we expected wetness, but we were forecast a dry day with quite a lot of sun - as good as we were likely to get.
Although parking in a similar place near to the end of the road to Langleeeford, our route was entirely different from the earlier one, with the start/end and summit being the only points in common. The path up Scald hill started as gravel track which turned through a gate to a grassy which split – we took the more northerly path on the way up and the other on the way down – not much between them. Once onto the ridge of Scald Hill the path became boggier and more peaty, with a few places where Caroline had a puzzle to get across – Martyn’s slightly longer legs spanning larger gaps, but there was nothing too bad and the feet stayed dry. Approaching the summit plateau the path crosses a stile and the luxury of flag stones over the boggier areas.
Ascending The Cheviot G/SB-001 - grassy path
Ascending The Cheviot G/SB-001 - getting peaty
The trig point is raised up on a stone plinth above a concrete base. As we were approaching the summit we heard CQ SOTA calls from the Lake District and managed to work 3 S2S on 2m using the handheld and rucksack antenna – Keith G1FVA/P on G/LD-027 Place Fell, Tom M7TJQ/P on G/LD-004 Skiddaw and Tony M7OUD/P on G/LD-012 High Stile. Dave G0EVV heard the S2S activity and called Caroline, so she had the hill qualified before setting up the main station!
The Cheviot G/SB-001 trig point
Martyn wandered off to investigate erecting the HF antenna in the boggier area between the trig point and fence, while Caroline set up the main VHF/UHF station on a grassy area close to the trig point. She was just about to start calling when Martyn came over – any chance of 2m contacts for him to qualify the hill? He had broken the HF antenna, snapping the wire as he attempted to get it up, so HF wasn’t likely to happen. Two quick 2m contacts in the log for him and he wandered back to the HF station, while Caroline continued calling on 2m and 70cms, getting a 70cms S2S with Tony M7OUD, and a 4th 70cms contact courtesy of Derek G1ZJQ who having worked her from home on 2m, then went for a walk to be able to make the 70cms contact!
The Cheviot G/SB-001 VHF/UHF
Martyn somehow manged to strip some wire back and make a temporary join to enable him to get the HF antenna in the air, for 5 contacts on 60m, followed by 9 on 40m. Martyn noted a spot for John PA/G4YSS/P on PA/PA-006, and was able to make the S2S. Martyn then made his way over to Caroline so she could bog hop over to the HF station for the S2S too – good to see John @G4YSS out activating again. Martyn wasn’t going to risk getting the repaired antenna up and down to change the links again so that was it for HF. While he tidied up and had late lunch Caroline continued on VHF/UHF ending up with 10 2m and 8 70cms contacts. A few people came by the trig as we operated, but only two lads stayed any length of time, having their lunch and a chat with Caroline.
The Cheviot G/SB-001 HF
It had started to get chilly on the summit with clouds coming over so it was time to descend, getting more views once we left the summit plateau. A pleasant walk, and not too boggy: 2:35 up and 2:10 down.
The Cheviot G/SB-001 Last look at trig
The Cheviot G/SB-001 stile at edge of plateau
Looking back at The Cheviot G/SB-001
23 September 2025: Tuesday - Tosson Hill G/SB-007
Time to head home after a fortnight of SOTAs, but we wanted to squeeze in another hill before returning to the flatlands of East Anglia. Tosson Hill G/SB-007 was a unique and a complete for both of us, and only half an hour’s drive from the cottage we had been staying in.
We had originally hoped to do a walk which included the full ridge of the Simonside Hills for the best views, but with a long drive still to come we went for the shortest there and back route, parking in the Simonside Forestry Commission Car Park south of Great Tosson. A path leads from the car park, initially fairly flat, but then ascending through trees by the Coe Burn. It was a lovely day, with sun and a few clouds and the path was quite busy. The path emerged onto a stony forest track climbing to the edge of the forest where views of the Simonside ridge appeared in front of us. We would have gone left for the main ridge walk, but went right along the forest edge, passing the point where circular ridge walk descended steeply to the forest track to continue further west. The track became narrower before coming to the gate at the edge of the forest leading to a path through heathland.
Simonside ridge (not climbed)
Eventually a white painted trig point appeared sticking up above a low shelter. It was a perfect day for SOTA activating; sun, light cloud, and a gentle breeze, and unlike rocky but slightly lower Simonside we had the flattish summit to ourselves. As we arrived at the summit, we heard two Lake District summit stations and both worked M7TJQ/P Tom on G/LD-005 Great Gable and M7OUD/P Tony on G/LD-020 Dale Head for 2m S2S with the handheld and rucksack antenna.
Tosson Hill G/SB-007 trig
Caroline then set up VHF/UHF using the trig point to support the antenna, while Martyn set up HF in the heather the other side of the path. Having broken his main HF antenna on the Cheviot he was using the spare which has fewer bands – but we wouldn’t have time for lots of band swaps. With a 70cms capable antenna Caroline then worked both the LD summits on 70cms and then picked up two more 2m and 70cms local contacts, so wasn’t too worried when it then went quiet as she was qualified on two bands. Time for some lunch.
Tosson Hill G/SB-007 VHF/UHF
Tosson Hill G/SB-007 HF
Meanwhile Martyn had got 5 contacts on 60m, before changing the links to 40m when he noted S2S opportunities, both of us getting DL/PA3FYG/P on DM/BW-103 and Rod MW0JLA/P on GW/NW-075. Deciding we didn’t have time to run on 40m, Martyn did some search and pounce for another couple of contacts while eating lunch. Caroline returned to VHF/UHF getting a few more calls. Doing final 2m calls while Martyn took down the HF station, she was called by a very weak M7OUD/P who was now on Robinson G/LD-021, eventually managing a 31/33 exchange, though a better position had been found when Martyn came for the S2S – 42/33. Despite the weak 2m signal Tony suggested trying 70cms and Caroline was surprised that he was a solid 59 there for a 59/55 exchange. Tony remarked he had often found 70cms better than 2m that day, but not that much. Caroline ended up with 10 2m and 6 70cms contacts.
Despite the lovely weather and the attraction of the main Simonside ridge, we needed to go home, so packed up and descended by the way we had come, taking 1 hour, compared to 1:40 on the way up for an about 9km round trip.
Tosson Hill G/SB-007 views
Now done.
  • Total miles driven 1391.
  • 18 summits activated netting 39 points which took Caroline over 2500 points
  • All uniques for Caroline, 15 uniques for Martyn, taking us both over 600 uniques - Caroline just needs to do Peel Fell to match Martyn’s uniques.
  • Caroline qualified (4 or more contacts) 10 summits for 26 points on 70cms and 15 for 36 points on 2m. Particular thanks to the Aberdeen lunchtime net usually to be found on 145.550 for VHF and UHF contacts.
  • HF conditions weren’t particularly good, so relatively low QSO counts.
  • Caroline: 336 QSOs, 70 on 70cms FM, 118 on 2m FM, 4 on 15m SSB, 39 on 20m SSB, 105 on 40m SSB.
  • Martyn: 233 QSOs, 1 on 70cms FM, 19 on 2m FM, 66 on 20m SSB, 90 on 40m SSB, 77 on 60m SSB.
Equipment:
  • FT-817, FT-818, Kenwood TH-F7E.
  • Linked dipoles for HF
  • SOTAbeams rucksack antenna for VHF, SOTAbeams MFD for VHF/UHF, RH-770 for VHF/UHF.
  • Equipment damage: Cracked connection on 2m MFD and another on a support pole - both repaired with tape to allow use for rest of trip. Broken HF linked dipole on the Cheviot, temporary repair on summit, but spare used for following summit.
Thank you for the comprehensive reports of your trip.
Some nice figures from your trip! Particularly good work with the qualifications on V/UHF. :+1:
