Trans-Atlantic S2S Event - 4th November 2023 - post-event reports
WOW indeed. Pete you were 599 on 10m CW just before I packed up at 16:30z.
I would have loved to have stayed on my summit for a few more T/A S2S, but I was losing feeling in my hands and had indeed lost feeling in my toes. Even though the summit is only 251m above sea level, the stiff breeze was very cold and being an environmentally sensitive site I hadn’t erected any shelter.
Full report to follow, but in the meantime… WOW
73, Gerald GM4OIG/P on Arthur’s Seat GM/SS-252, along with several hundred other members of humanity during my stay (plus a few crows). :grinning:
Looks like a fabulous day for 10m. Unfornately I’ve got a stinking cold, so it wasn’t wise for me to be up a cold hill in the Lakes.
Next time! Mark M0NOM.
Gerald…u were very strong over here also. You were so strong I had a hard time believing it…“That can’t be Gerald!”
I stayed on 10 almost the whole time…and I kept loosing my frequency to bigger stations…that was annoying.
But every time I moved and spotted myself more Europe stations would call me…It looks like I worked 50 Europe stations on 10 meters…MANY are s2s contacts…
Crazy
Thanks for being there my friend!!!
Pete
WA7JTM
Went with the 30 min drive today instead of 2.5hrs. Decided to go to the NJ SOTA training grounds of W2/NJ-008 High point mountain with Greg KG6PTL. A lot of fun working everyone in the the transatlantic event. 10m ssb was king! Worked 13 dx S2S and 4 NA S2S. Having the power with the 891 really helped I’m sure. Used my @NY4G 100w 40m efhw. Worked well. Great day.
That was very,very, very… good. I was missing antenna for 10m so much :smiling_face_with_tear: but 15m band didn’t let me down. Amount of QSOs with west coast is impressive, 4 NA S2S is also very good, and finally logged @wG0AT. Signals at the last moments of sunset was amassing got S9+ from NA. I got inspired to work on portable beam antenna for the next event :). Thanks for chasing and S2S OMs.
100W and LB8CG multi-band vertical antenna:
Well, it’s taking me some effort and time to process what just happened!
Apologies in advance, I’ll try to get my information across as efficiently as I can, but the story has a few elements and it’s a subject that I’m passionate about!
I worked Barry N1EU when he was living in NY State a few times with my RockMites. Barry loved chasing QRPp signals. I was always thrilled to work across the pond with my flea power. One thing bothered me though, the radios had been built from bought kits. I wanted a home brew transatlantic QSO. I was tempted to the dark side of SSB and I built a home brew 20m SSB transceiver from scratch. On my first activation with the SSB transceiver, I worked several VK stations - to this day, my proudest ham radio achievement. I still hadn’t got that transatlantic QSO though! Barry to the rescue! I arranged a sked with Barry N1EU and I was able to manage a scratchy S2S with my home brew SSB rig. You would think that my itch had been scratched, but no, I still felt disappointed that I’d never managed a home brew transatlantic CW QSO.
A home brew (not built from a kit) transatlantic QSO has been my target for several years. At first, I built a Manhattan style RockMite 20 on a tuna can, I’d worked Barry N1EU plenty of times on my kit built RockMite 20. Unfortunately the keen SOTA chasers from the east coast US seem to have moved on to pastures new (purely anecdotal).
I didn’t have much joy with my Tuna can RockMite, so I decided to build something with a bit more power. I’d designed a PCB for SMD components to do my ‘construct an SMD project on a SOTA summit’ project. The transmitter was built for 40m and puts out about 2 watts. I had ordered 5 circuit boards and only used two - one built as practice and then one built on the summit of Ingleborough. I reckoned it would be fairly simple to build one of the transmitter boards and modify it for 20m. The Kendal Mint rig was born - about 2 watts on 20m with a direct conversion receiver.
No joy with the Kendal Mint rig either :confused: I quite enjoy using the rig and 2 watts output should be quite useful.
I was driving along the road on Thursday lunchtime this week and I suddenly had the idea that I could try to build a 15m RockMite for the transatlantic event. Some 21.060MHz crystals had been delivered with the mail that morning, intended for a project in the future. I couldn’t get the thought out of my head and on Thursday evening, I located one of my RockMite PCBs I started building. By 1021 yesterday morning, I’d successfully done the smoke test!
In addition, I finished off my mini amplifier to boost my RockMites a little bit. I put together a low pass filter for 15m last night for the amplifier. I’d built the amplifier with a socket for different low pass filters and had intended to use it with my scratch built RockMite 17.
Time was running out and I discovered last night that my RockMite 15m had chirp - I’d been giving it a health check. I did a bit of thinking overnight and reckoned that the oscillator feedback capacitors were too large in value. At 7am this morning I was in the shack swapping capacitors! Thankfully with the reduced value feedback capacitors, the chirp was much reduced.
For fun, I thought that I would do a home brew theme for the transatlantic QSO party. I thought it would be my best chance for a home brew transatlantic CW QSO in a while. I chose to activate Ingleborough G/NP-005 as it has excellent take off to the west over Morecambe Bay. Ingleborough is my nearest summit too, although it’s a decent walk from whichever route you tackle it.
I started off with my Kendal mint rig - I thought that there was a slim chance of an early transatlantic QSO on 20m before the higher bands got going. My rig is crystal controlled on a fixed frequency and my QRL? was answered with ‘yes’. Bummer. I listened for a bit and it was Jens HB9EKO/P using the frequency. Oh well, at least I could call in for an S2S! I worked Jens on HB/ZH-004 and then waited, hoping that Jens would QSY, however he seemed to be having too much fun!
I was worried about not getting a free frequency with my other rigs, so I decided to set up on 15m with my new RockMite and amplifier, I see around 3 watts maximum with that combination.
I was thankful to find the 15m frequency quite clear, so I called CQ. EA1AER found me first, followed by OE6GND. The RockMite worked! I then had a bit of a surprise- I was called by KF9D! Oh my goodness I had done it! My 4th QSO was transatlantic! I think my Morse went a bit wobbly after that! 15m just kept producing the QSOs, my brain was turning to mush! A few minutes after my first transatlantic QSO I worked N6PKT in Arizona - not only transatlantic but west coast! K8ITU provided my first transatlantic S2S operating from W8V/PH-082. The DX S2S just kept coming and I couldn’t really believe I was doing it with gear built in a couple of days in my shed!
Eventually I reckoned I ought to try my 17m RockMite and I worked a few, including Roy WN3F on W4V/SH-030 for the second time (I’d worked Roy on the RockMite 15). Roy won’t know how special that QSO was to me - the RockMite 17m is truly scratch built, no circuit board in sight. I’d done it properly - a proper scratch built transatlantic CW QSO and it was an S2S too! Does it get any better?!
A very successful project and outing. What next?
Transatlantic QSOs -
KF9D, N6PKT, WF4I, K8ITU S2S W8V/PH-082, ND0C, K6YK, WB2FUV S2S W2/GC-020, WN3F S2S W4V/SH-030 (×2), NM3A S2S W3/PT-007, WB6POT, AC1Z S2S W1/NL-017, VA2EO S2S VE2/ES-034, K8LJG, N0UR
73, Colin
Many thanks to the SOTA operators on summits in EU today, especially those wet places !! Total of 74 QRP CW QSOs 40/20/17/15/12/10M including 16 EU S2S. Rig was FT-818 at 5 watts to 40M EFHW Inverted-7 up 22 feet on rock. Disappointed that I missed a few EU s2s when home stations kept calling over me. :frowning: :frowning:
Stay well & 73!
Mike, WB2FUV
Hi everyone,
It’s been simply AWESOME, thanks so much.
I planned for an activation on a slightly better weather time frame, and an unexpected phone call from Javi, @EA2GM, on visit in Pamplona transformed the outing into a joint activation!
The heavy rain we had all morning dissolved just at 14:00 and off we went to the summit.
Sky opened but we found very strong wind and gust.
No way to put the shelter unless we wanted to see it flying away. My bigger wire antennas stayed inside the backpack as well.
We adapted to the situation and put the smaller antenna we had, a 28 MHz EFHW. Seems we did the right choice as we found the band crowded and spent two hours in this freq. We ran 10w from the KX3 and were astonished to get lots of transatlantic qso, while the wire was waving and at times even seating partly on ground due to gust.
Javi installed a second station with his FT-817 and threw the wire over a nearby tree.
His antenna was also swinging furiously but still worked fine to log in 12-15-17 meters.
After a great time absorbed logging in a hurry lots of DX we saw a weather worsening and the sun going down.
Time to stop and return safe and sound.
We logged 12 S2S each, and were chased from LU and PY, along with a few EU.
I enjoyed very much greeting S2S to many NAs that I use to chase from home, it was so good to change role today!
Combined activation results:
QSO = 55 QSO
S2S NA = 14
S2S EU = 2
Chasers NA = 9
Chasers SA = 3
73 de Ignacio / Javi
EA2GM on 10m
EA2GM on 12m (2nd station)
EA2BD on 15m
Well that’s 2x QRP to QRP contacts to the USA that I know I had today. You on 15m for an S2S and Randy ND0C (5W to a beam) on 10m.
Thanks for the QSO! :slight_smile:
Great to get you in the log today!
Hey Guys,
I made also very good contacts in Tenerife.
Only QRP 5W with my EndFet as inverted V.
I should have stay longer on the peaks saw that the conditions on 10m were awesome. But during night going down where no path exist is bad.
Also managed to make some S2S. But with my 5W the other station interrupt me all time!
Big thanks for this special day and thx for all other sota activators!
Julian
I little more info on today’s event from Arizona…
running Yaesu FT818 with 30 watt amp to a Link Dipole at 12 ft, on W7A/CS-031
97 total QSO’s…all CW…a few on 15 and 40 (USA ops)
50 EU QSO’s all on 10 Meters
At least 8 EU s2s QSO’s…
Two EU stations signed as /M (mobile I assume)
16 DXCC countries worked in Europe…Belarus the furthest…maybe Hi HI
Argentina also worked…
Many USA s2s QSO’s…not sure how many yet since I never write them down in the field…just note they are s2s
It will be a while before I post the log…WIFE…Dinner…gotta pay the piper!!!
Pete
WA7JTM
W7A
it’s such fun to read everyone’s experiences in this event! I was on W6/CT-228.
I left the house at 13Z, hit the trail at 1335Z, and topped out 30 minutes later. My first QSO was at 1436Z so it took about a half hour to set up the 10 meter half square and the gear on an unfamiliar summit. Nice to have a bench! All QSOs were made with 5 watts. The half square ends were less than a foot off the ground, but the dropoff to EU was hundreds of feet.
From 1435Z to 1800Z I alternated between CQs and hunting S2S. I wish I’d been able to put up a second antenna for 12/15/17. There was a lot of action on those bands. LB8CG had a fine signal on 15, but couldn’t hear me. So be it, 10 was pretty darned good!
61 QSOs were logged (20 EU, 1 SA) including 20 S2S; 7 were with EU, 1 AF, 11 NA including KP4 and two VA2. Notable signals were GM0GAV, OE5EEP, HB9/OE9HRV (SSB!) which made the S2S easy.
The half square antennas seem to work well. I would like to rig two up end to end with the feeds meeting in the middle at the rig. 50 feet between the feed points may provide enough isolation on 15/12 or 12/10. I might be able to pull this off atop Flint Peak, W6/CT-225.
Thanks for the QSOs and the thrills. I am looking forward to seeing K6ARK’s results with his 7 element wire yagi. Go, Adam!
72, David N6AN
Chose a drive-up summit so I could take lots of gear and decide what to do once I arrived. Put up a 20m vertical and got an even mix of Europe and USA. Then set up a PAC-12 vertical for 10m and had more fun. Made my first SSB SOTA QSOs (thanks @GM4JXP and @KJ7QPD). K1 on 20, FT817ND on 10. 28 contacts, 8 TransAtlantic S2S, 7 stateside S2S. Heard several EU SOTA who had big EU pile-ups. Wonderful couple of hours.
What an amazing day, full of SOTA DX! The conditions, activity, and signals were all impressive. I ended up with 45 QSOs in 20 countries from my home station using 5 watts. The European operators were great with nice signals and good ears. What a fun event!
Randy, ND0C
I picked a summit where I could car camp near the peak, which ended up being Fremont Peak W6/CC-055. I decided to summit in the dark, waking up at 4am local time, so I didn’t miss any of the action–turned out that I way overcompensated and didn’t even hear a European until almost an hour and a half on the summit. I got to experience some much longer distance 40m contacts than usual though! Finally when the sun rose more than 2 hours after summitting the Europeans started to file in. The countries I hit (stars indicate all time new countries): US, Canada, England, Argentina, Germany*, France, Slovenia, Switzerland*, Czech Republic*, Spain, Belgium*, Scotland*, Wales*, and Portugal*!
Two moments of embarrassment… 1. I was struggling to copy HB9DQM/P, asking for callsign repeats, and my paddle decides to start sticking, making the problem much worse than it otherwise should have been. Thanks for sticking with me, the Swiss S2S was a highlight! 2. I heard S57S as “S2S” more times in a row than I am proud to admit, and I could not figure out why this S2S caller would not just go ahead and give their callsign…
Yes Randy it was very good!!
Next time I need a little more power😜
That’s the case: Chasers from home also take part in every S2S event…
It would be nice to have an event with only stations that are on a summit…
But that’s probably not very realistic :face_with_raised_eyebrow:
The thought came to me when I called a CQ calling station at a summit in the USA yesterday. He also replied S2S only, but that didn’t stop the European chasers from continuing to call for him. He then worked through the most aggressively calling chasers so that he had the peace and quiet to conduct a QSO with me.
Some chasers probably have the opinion: if everyone thinks about themselves - everyone is thought of!
Tnx for the QSO Colin - great job!
Randy, ND0C
