Continuing the discussion from Trans-Atlantic S2S Event 23rd April 2022 (Part 1) - #101 by DL2DVE.
Previous discussions:
“…bringing the mast down to change the jumper takes too long. Need to make a design with traps.”
Precisely the problem with my vertical and mine is only for 20m and 17m. I too worked with a mis-matched antenna for a couple of QSOs. Maybe as the higher bands improve, there will be a need for a more complex design.
Well done on your activation Andy. I am pleased to see that I am not the only madman carrying 14kg around in the mountains!
