Hi,
I want so share some tool with you that I wrote to make it easier to type my paper sota logs into the computer and creating a CSV file.
It is a command line application that works fine on linux and mac os and requires python3 and python3-requests to run.
You can find it here: GitHub - asdil12/sotareport: Tool for submitting SOTA (Summits on the Air) radio connection logs to the SOTAdata database.
Using it looks like this:
./sotareport.py output.csv
Enter station info:
Your Callsign: HB3/DO3IC
Your Summit: HB/AI-013
Found Summit: Furgglenfirst (1952m), Appenzell Innerrhoden, Switzerland
Date (DD/MM/YY): 26/06/20
Adding log to 'output.csv' - Press CTRL+C to edit previous QSOs or exit
Enter QSO #1:
Time (HHMM - UTC): 1215
Callsign: HB9EAJ/P
Freq (21MHz/80m): 29MHz
Mode (CW/SSB/FM):
S2S Summit: HB/SO-003
Found Summit: Röti (1395m), Solothurn, Switzerland
Distance: 144km
Comment:
Enter QSO #2:
Time (HHMM - UTC): 1220
Callsign: HB9GUX/p
Freq (21MHz/80m): 28MHz
Mode (CW/SSB/FM): SSB
S2S Summit: HB/GR-294
Found Summit: Chrüz (2196m), Graubünden, Switzerland
Distance: 41km
Comment:
Enter QSO #3:
Time (HHMM - UTC):
Error: Invalid time format - use HHMM or HH:MM 24h UTC
Time (HHMM - UTC): 1221
Callsign: EA2DT
S2S Summit:
Comment:
Enter QSO #4:
Time (HHMM - UTC): 1223
Callsign: DB7MM
S2S Summit:
Comment:
Available Commands:
E <num> : Edit QSO <num>
C : Continue entering logs
S : Save and exit
cmd> s
