Today I shamelessly played the winter-bonus card and activated both Great Mell Fell G/LD-035 and Little Mell Fell G/LD-037 on a beautiful winters day.
Great Mell Fell
| WOTA ID: LDW-155 | Height: 537 m (1762 ft) |
| SOTA ID: G/LD-035 | Grid ref: NY396253 |
| HuMP ID: n/a | QTH Locator: IO84MO |
This was my first time on Great Mell Fell. It is a summit that I have never chased from home on 2m FM. The journey over Kirkstone Pass from Windermere never gets old, past Ullswater’s western shores before turning towards Matterdale End. There is ample parking opposite Brownrigg Farm at 54° 36.809’ N, 2° 55.151’ W.
I followed @G4OBK Phil’s instructions, and avoided the direct path through the woods, instead sticking to the farmers track until I reached the next stile, for the northerly track.
Today I used the Super Antenna MP1 with lightweight tripod, a tripod guying kit, the IC-705 using the speaker mic at 10w with a LifePo4 4200 mah battery. CW was using my Palm Pico Paddles.
For 2m I’d crudely cut four radial for a ground plane and used the Super Antenna’s telescopic whip with about 5 sections showing. It seemed to work reasonably well.
I’d pre-arranged to have 2m cw contacts with Rick 2E0FRS and Andy @G8CPZ - all good practice, however I felt it was too cold to attempt a CW activation.
The Super Antenna worked brilliantly and I was surprised to get two transatlantic chasers. Some lovely summit to summits including @G4WSB Bill who was on High Street (one of my favourites) and who I was to catch later on Stony Cove Pike for two independent S2S when I was on Little Mell Fell.
Helvellyn
| TIME | CALLSIGN | BAND | MODE | RST | RSR | OPERATOR | SIG | REF |
| 11:47 | 2E0FRS | 2m | CW | 599 | 429 | Richard Haughton | ||
| 11:52 | G8CPZ | 2m | CW | 559 | 539 | AJ Barth | ||
| 11:56 | 2E0FRS | 2m | CW | 559 | 429 | Richard Haughton | ||
| 12:00 | G0TDM | 2m | FM | 59 | 59 | John Sutton | ||
| 12:04 | G0PMJ | 2m | FM | 59 | 54 | Dave | ||
| 12:07 | G8CPZ | 2m | FM | 55 | 52 | AJ Barth | ||
| 12:08 | G4ZRP | 2m | FM | 52 | 52 | Brian | ||
| 12:21 | G7KSE/P | 2m | FM | 59 | 59 | Alex Hill | SOTA | G/LD-004 |
| 12:24 | SV2OXW | 20m | SSB | 59 | 33 | makis boulousis | ||
| 12:26 | OH1MM | 20m | SSB | 56 | 59 | Pasi Alanko | ||
| 12:27 | EA2/F5ODQ/P | 20m | SSB | 59 | 59 | ALAIN DUCASSOU | SOTA | EA2/NV-093 |
| 12:28 | CT2HOV/P | 20m | SSB | 55 | 55 | Nuno Pereira Gomes | SOTA | CT/DL-009 |
| 12:30 | G6WSB/P | 2m | FM | 59 | 59 | SOTA | G/LD-011 | |
| 12:35 | IX1IHR | 20m | SSB | 55 | 55 | CLAUDIO FREZET | ||
| 12:35 | EA2DT | 20m | SSB | 55 | 55 | Manuel | ||
| 12:35 | EA1DHB | 20m | SSB | 59 | 59 | Ricardo Pena | ||
| 12:37 | SV2RUJ/P | 20m | SSB | 57 | 55 | Stavros Triadafyllo | SOTA | SV/TL-065 |
| 12:37 | OH3GZ | 20m | SSB | 59 | 59 | JUKKA " Jack " KOVA | ||
| 12:37 | M7BIA/P | 20m | SSB | 57 | 44 | Martin Shakeshaft | SOTA | GW/NW-042 |
| 12:38 | LZ3SM | 20m | SSB | 59 | 55 | SVETOZAR GERASHEV | ||
| 12:39 | N2BTZ | 20m | SSB | 57 | 55 | JON J TRULAND | ||
| 12:40 | EB1IFK | 20m | SSB | 59 | 55 | Santiago Creo Batal | ||
| 12:40 | W1OW | 20m | SSB | 55 | 55 | William R Smith | ||
| 12:40 | EA2EVM | 20m | SSB | 59 | 55 | Cesareo Garcia Andr | ||
| 12:40 | EA4BQG | 20m | SSB | 59 | 57 | GUILLERMO ALCALA DE | ||
| 12:41 | OM1AX | 20m | SSB | 59 | 59 | VLADO RABEK | ||
| 12:41 | OE5MZL | 20m | SSB | 59 | 56 | Martin | ||
| 12:42 | EA1GKP | 20m | SSB | 59 | 55 | JUSTO HERRERO ALONS | ||
| 12:42 | EA2EVC | 20m | SSB | 59 | 55 | Óscar López | ||
| 12:43 | OE6ADE/P | 20m | SSB | 59 | 59 | Andy Andreas Domani | SOTA | OE/SB-168 |
| 12:56 | M0DXT | 40m | SSB | 59 | 55 | William Tinnion [BI | ||
| 12:56 | G0FEX | 40m | SSB | 59 | 56 | KEN PORTER | ||
| 12:56 | G4IVV | 40m | SSB | 57 | 55 | Jonathan Perkins | ||
| 12:57 | G0FVH | 40m | SSB | 57 | 44 | DAVID. S. DOLLING |
In between Great Mell Fell and Little Mell Fell I had lunch using the JetBoil to provide hot water for a welcome coffee and a pot of rice. The drive to Little Mell Fell takes around 10 minutes at most
Little Mell Fell
| WOTA ID: LDW-173 | Height: 505 m (1657 ft) |
| SOTA ID: G/LD-037 | Grid ref: NY423240 |
| HuMP ID: n/a | QTH Locator: IO84NO |
I parked on the road at the standard place to ascend Little Mell Fell. There were a few Wainwright Baggers making the trip including a couple of groups who’d I’d seen earlier on Great Mell Fell. The ascent of the Little’un is much shorter, a short and sharp 20 minutes to the summit.
Wonderfully the biting although light breeze on Great Mell Fell had dropped away and I appreciated an hours worth of activating in relative comfort, until the wind picked up again. I did take a tarp with me but didn’t end up setting it up. Should have left it in the car!
Mandatory Sheep Photo
Ullswater
Parking Position
Great Mell Fell from Little Mell Fell
Penrith
| 14:35 | DD0VE | 20m | SSB | 59 | 59 | Ralf Mantyk | ||
| 14:36 | HB9CGA | 20m | SSB | 59 | 59 | ULRICH LENHERR | ||
| 14:36 | DL0KL | 20m | SSB | 59 | 59 | Immo Messner | ||
| 14:36 | EA2IF | 20m | SSB | 59 | 59 | Op. Guru . | ||
| 14:38 | DL/HB9EAJ/P | 20m | SSB | 59 | 57 | Stephan Schmid | SOTA | DM/BW-640 |
| 14:39 | EA2DT | 20m | SSB | 57 | 52 | Manuel | ||
| 14:39 | F5JKK | 20m | SSB | 59 | 57 | Éric JAUCH | ||
| 14:40 | EA2DDG | 20m | SSB | 55 | 55 | Jose Maria Gonzalez | ||
| 14:41 | SV3IEG | 20m | SSB | 59 | 55 | Dinos KRASSAS | ||
| 14:41 | OK1SDE | 20m | SSB | 59 | 59 | Dalibor ( Borek ) W | ||
| 14:42 | EA3EVL | 20m | SSB | 53 | 52 | PABLO PANISELLO | ||
| 14:43 | SV3IEG | 20m | SSB | 55 | 55 | Dinos KRASSAS | ||
| 14:44 | IU1KGS | 20m | SSB | 55 | 51 | Carlo G | ||
| 14:44 | EA2CCG | 20m | SSB | 59 | 57 | Joaquín Montoya Jim | ||
| 14:45 | EA1AAP | 20m | SSB | 57 | 55 | Fernando Manzanares | ||
| 14:45 | SP7MW | 20m | SSB | 59 | 55 | Marek W. | ||
| 14:46 | SM6CNX | 20m | SSB | 52 | 52 | DAN FRANZÉN | ||
| 14:46 | OH3GZ | 20m | SSB | 59 | 59 | JUKKA " Jack " KOVA | ||
| 14:47 | OH6LS | 20m | SSB | 59 | 57 | Lasse S | ||
| 14:47 | G0TDM | 20m | SSB | 59 | 59 | John Sutton | ||
| 14:50 | G4WSB/P | 20m | SSB | 59 | 59 | Bill Bowditch | SOTA | G/LD-018 |
| 14:57 | G8CPZ/P | 2m | CW | 519 | 539 | AJ Barth | SOTA | G/LD-058 |
| 15:01 | G0TDM | 2m | CW | 599 | 599 | John Sutton | ||
| 15:11 | G0RQL | 40m | SSB | 59 | 59 | DON ROOMES | ||
| 15:12 | GW4VPX | 40m | SSB | 59 | 55 | ALLAN JONES | ||
| 15:12 | M0JLA | 40m | SSB | 59 | 47 | Rod M0JLA | ||
| 15:13 | PA5KM | 40m | SSB | 59 | 45 | Coen Vermaire | ||
| 15:13 | M0BOB | 40m | SSB | 59 | 33 | Bob Adlington | ||
| 15:15 | GI0AZA | 40m | SSB | 59 | 33 | Esther JM Harper | ||
| 15:16 | 2E0FEH | 40m | SSB | 59 | 33 | Karl Kruger | ||
| 15:28 | EA5FPL | 17m | SSB | 59 | 59 | FRANCISCO PEREZ LAC | ||
| 15:39 | M0YMC | 15m | SSB | 59 | 33 | Mal |
Wonderful to have an armchair copy chat with Guru @EA2IF and was lovely to wish him a Happy Birthday in person. 40m was a proper-bun fight an finding a clear frequency very difficult so apologies to chasers who were experiencing QRM. A nice ground-wave 15m contact with Mal M0YMC near Carlisle.
Thank you all for the wonderful contacts. All photos here.
