The final push to Mountain Goat
With the usual holiday time around Christmas I decided to make a come back to SOTA. My activating activities started to fade around 2020, when I found much joy in building HF Yagi’s and more recently phased arrays for the low HF bands. In 2022 I also moved QTH back to North Wales, where the fun really started with radio and a lot less sleep…
Back to SOTA. Unfortunately it was left on a bit of a cliff hanger with near 900 ish activator points. Possibly with a good couple of months the MG could have been achieved 5 years ago or more. The KX3 has been paired with a new LiFepo4 battery and I am back out there. Early next year MG is looking promising. Steady progress
My CW practice is improving, first QSO in 2026 is looking more likely. Morse Mania is a great help with this journey. Funny moment tonight trying to whistle my callsign to M1GEO, I couldn’t help but laugh !
GW/NW-073 (Mynydd Rhyd Ddu)
Fairly typical run on 40m followed by 60m with many familiar voices back in the log. The ascent is very straight forward from a near by farm track. Highly recommended if you haven’t been under a wind turbine before now ! Note I positioned carefully between the cow waste :wink:
GW/NW-027 (Arenig Fach)
The following day the weather was excellent, be it rather cold. I decided on Arenig Fach. Charmaine and myself had a day climbing up Arenig Fawr in the summer ( with no radio sadly ). The summit has a particuarly difficult ascent with most of its path concealed by dense vegetation.
Arenig Fawr in the background.
GW/NW-043 (Cyrn-y-Brain)
A bit of dash tonight, no external PA resulting in a 15W activation when the extra power would have been a great help. George M1GEO managed the contact on 80m as well as ON3WAB. Roger MW0IDX got the contact on 20m across North Wales. I knew I was pushing my luck with the short skip propagation on HF, but that part of fun for me.
I will update the report topic as the 1000 point mark approaches.
73, Jonathan GW2HFR/P
Good to catch you, Jonathan. You were tough on 80m, mainly due to Christmas lights in the village increasing the background hash by about 10dB! I thought I’d try CW in case it was easier on 60m, but 80m SSB was (marginally) better, and good enough for SSB.
Looking forward to it Jonathan! Please consider a possible joint activation celebration summit day, or just a pint when you get down. Be lovely to meet up again.
73 Gerald
Welcome back Jonathan…good to get you on Rhyd Ddu…another joint activation with Gerald on your MG day? :grinning_face:
73 Allan
Would love to see this happen.
Yes lets do that guy’s. I haven’t seen you both in while. Gerald I will always remember you taking me up Tryfan’s North Ridge. I suspect in these snowy conditions that climb would be a real adrenaline rush right now.
@G4TJC Can possibly join us also ?
Snow is up to the base of each vertical on the 4 square. Needless to say, it has de-tuned the array somewhat !
73, Jonathan
You can say that again. Would be quite awkward as it’ll be slippery with unconsolidated snow and verglass. I suspect slow progress and I’d definitely have a rope out for the top part just in case.
I soloed Crib Goch in winter about 30 years ago… but the snow was actually nicely consolidated so it was fairly straightforward. Obviously needed care. But OK.
I’m confident 2nd op would veto participation on that one. :cold_face:
