testing vimeo link posting.
Can I post a Vimeo video link?
EDIT: The answer is yes.
Thanks for your email response. Since I did not hear from you guys, I did some experimenting on my own and figured out the problem.
When you use the Share function on Vimeo and select Copy Link, it gives you something like this:
My problem is I removed the question mark and everything after; eg, ?share=copy. I assumed it was just extra stuff since I embeded Vimeo videos using just the URL without the ?share=copy (but not on reflector site). Once I added ?share=copy back to the url, the Vimeo Video appears in my post. Also, I see your test and it worked for you since you probably did not mess with the code.
