Motivation
Jorge EA2LU and I decided to go for our first 2022 activation to Mt. Baratxueta, a short hike although steep in the final part.
I took the chance to bring a new seat I have not used before. Some details about that further on.
Activation date January 3rd 2022.
Weather was foggy and when we reached the summit, the low clouds gave excellent scenery:
Hopefully there was little wind that morning and temperature was not very cold.
Setup
Jorge used his inverted L random wire and KX2, running in 5, 7, 10 and 14 MHz, mainly CW plus a couple of S2S in VHF with Alain EA2/F5ODQ/P, activating two summits in the north of EA2/NV.
I separated a bit and used my EFHW for 7 and 14 MHz SSB, and I chased some S2S in CW as well. Also had the S2S in VHF with F5ODQ, doing very well in these two summits; Alain is a keen hiker.
The sky was clear during the morning and I could see the lovely Pyrenees range with some snow:
Testing a collapsible chair
Jorge brought his tripod camping chair, as usual.
I also have a similar chair but find it a bit bulky, weight is about 900 gram.
As today’s summit is a grassy area I decided to grab a new chair I had not used on a mountain; it’s a foldable Trekker chair, that uses a foam sleeping mat as for the cushion:
When dismantled I put the collapsible frame inside the mat roll, hanging from my rucksack:
Total weight is 470 gram, therefore I saved some weight.
Result was satisfactory, although I could only use it on flat surfaces.
We finished glad with the activation and the chair.
See you soon from a new one, 73 de Ignacio
