Telescopic GP Whip vs EFHW.
Hello, I compared 2 antennas in Sota conditions. Both antennas are light, and extremly quick to install. The antennas are an EFHW (a clone home made PAR end Fed Trial 10/20/40 m) and a GP telescopic whip. I consider my clone home made PAR end Fed as a clear winner. More infos below.
Antenna EFHW description: A clone home made PAR end Fed Trial 10/20/40 m. Basically a home made 81:1 transformer, #10 m wire, followed by a #25 microH coil, followed by # 2 m wire. The 10 m wire is a half wave on 20 m, a full wave on 10 m, a 1/4 wave on 40m. The coil acts as a choke on 10/20m. On 40 m, the coil + the #2m wire acts as the 2nd 1/4 wave on 40m , therefore, the whole is a shortened 40m EFHW. Total length about 12.5 m. I used a #6m carbon fishing rod as a mast. The antenna is installed as a sloping wire. The top of the antenna is #6m high, the bottom, with the 81:1 transformer is 1m high. The antenna has been adjusted for resonnance on 10/20/40 and can be used without ATU. Very little sensitivity to the environment.
Antenna GP : Telecopic antenna # 5.7 m long. See the thread “Cheap 1/4 wave Antenna whip from Aliexpress”. I used 2 X 5 m radials on the ground, and a home made choke at the feedpoint. I used the full length of the telescopic # 5.6m, and the ATU from my KX2. I did not adust the length of the telecopic part for resonnance, just used the KX2 ATU
How I did the comparison.I installed both antennas on a nearby hill. I called CQ de F5MOG for a few minutes, with antenna EFHW, and with the GP. I get the SNR data from the RBN network and I compared the obtained data.
Date of test for 20 m Feb 24, 13:26-13:27 for EFHW and 13:28-13:29 for GP
Date of test for 40 m Feb 24, 13:32-13:33 for GP and 13:35-13:36 for GP
For all tests I used my KX2, same power, about 10 W, same coaxial cable.
Well, same location, same power, same time, same conditions, or close enough to consider the comparison as valuable and meaningful.
The tables below shows the SNR dB received from the RBN network, for the EFHW and for the GP.
On 20 m, almost ALL the reports are higher for the EFHW.
Indicatif EFHW GP
2E0INH 12 4
DF2CK 29 23
DK3WW 31 23
DL0PF 25 8
DL1HWS 23 15
DL1HWS-3 26 15
DL8LAS 16 9
DL8TG 25 18
DL9GTB 33 28
DM5GG 17 17
DM6EE 25 18
DO4ZT 21 13
DXSDR 10
EA5WU 15 12
ES2RR 8 5
ES5PC 21 17
F4GOU 21 19
G0KTN 19 11
G3XBI 14
G3YPP 12
G4IRN 17 12
G4ZFE 12 15
GE0FRE 13
GI4DOH-2 17
GX0FRE 13 5
HA1VHF 17 13
HA6PX 9 9
HA8TKS 10 11
HG0Y 26 17
HG8A 10 11
IK7YTT 18 19
LZ4AE 7
LZ5DI 5
LZ7AA 5
MM0ZBH 18
OE6TZE 10
OK1FCJ 30 21
OK1HRA 25 16
OL9A 16 9
OZ1AAB 4
PA8MM 11 4
PE5TT 8 3
PI4CC 20 10
R1LB 16
RK3TD-2 8
S50ARX 7
S50U 12 3
S53M-11 25 19
S53WW 27 20
SE5E 21 15
SM1HEV 4
SM7IUN 24 13
SQ5J 14 9
SQ5OUO 7 6
YO2CK 9 7
YO2MAX 15
On 40 m, ALL the reports are higher for the EFHW. A lot more reports received on the EFHW.
Indicatif EFHW GP
DC8YZ 25 18
DF2CK 12 7
DK0TE 12
DK3WW 11
DK9IP 4
DK9IP-1 6
DL0PF 22 18
DL8TG 11
DL9GTB 8 5
DP5G-15 12
DR4W 10
F4GOU 17 10
F4VVG 3
F6KGL 16 8
HA1VHF 1
IK4VET 5 6
OE6TZE 6
OK1FCJ 14
OK1HRA 10 9
PA8MM 9
PE5TT 5
PI4CC 13
S50ARX 14
Hi Pierre,
Interesting observations, thanks for sharing!
Some preliminary observations:
  • Using only 2x5m radials with the GP is not optimal. I prefer many but shorter ones, e.g. at least 8 that are 2.5m long.
  • On 40m the GP is shorter and therefore probably less efficient than the EFHW.
  • Especially on 20m, the EFHW has some preferred directions.
  • Since the GP is vertically polarised, (near) NVIS won’t work. Therefore your EFHW in sloper configuration should be much better with closed-by stations. It would be interesting to configure the EFHW as inverted-L or inverted-7 (this could probably improve your results even more).
  • There was at least one tree in the vicinity which may have a greater effect on your vertical polarised GP, compared to the EFHW.
  • Having a 2-4 minute measurement time difference can also have a propagation effect.
But it’s true, when I did some experiments myself, testing both antennas (the same EFHW as inverted-7 and the same GP) on 10m, sometimes the EFHW was the winner and sometimes the GP (mostly testing with stable groundwave RX and TX).
I know some summits that work better with the GP and some that “prefer” the EFHW. When I’m surrounded by trees, I usually choose the EFHW. Another advantage of the EFHW is that you don’t have to change the antenna when you change bands (I don’t use an ATU).
There are so many variables involved, which is part of the fun!
73 Stephan
I also think 2 x 5 m radials is far from ideal. I use mine with at least 5 radials of 2.5 m.
Well, with a 20 m long efhw, you can theoretically use 40 20 15 and 10 but the reality is that so many nulls in the patterns for the higher bands make the antenna barely usable at those frequencies, imho. So you can use 2 (or 3) bands without modifying the antenna
 Not that great.
With the telescopic gp, you can use every single band from 20 to 10 m without atu and at its ‘proper’ physical length. You can also easily add 30 and 40 m with a coil. Only a few seconds are required to change the length of the telescopic whip. Concerning antenna directivity, as an activator, the 360° uniform pattern can also be an advantage to get as many chasers, from every directions, as possible.
Since I got the vertical whip, I have to deal with crazy pileups that I never experienced with my efhw. Things like 40 QSO in 25 min never happened to me before. Maybe the bands are better or it’s just a coincidence but now I have 9 activations with the whip and so far, it’s been superior.
Add to this the ease of setup of the telescopic compared to guying a mast and dealing with 20m of wire when on a cold summit
 Now my efhw’s stay in the drawer !
I had avoided the EFLW and EFHW antennas in the past because a dipole or vertical would be a better radiator for lower power operators out in the field
The Chameleon antennas with their balun was another antenna I found lacking in performance when I am running QRP
Remember, 5 watts on SSB is a struggle so every db helps
All these baluns and chokes in the above I believe provides less results than what I am finding using a resonant vertical or inverted vee dipole. Maybe the single wire style of deployment in a horizontal or sloper set up is different enough from the 2 wire antennas
There is a lot of convenience to using the those antennas with higher power and when bands are in great shape and you will get 59s and work some DX based on the deployment style. I use these antennas when I can get the far end up high or off a mast
I have been A/Bing a Chelegance MC-750 vertical against their MC-599 dipole and at times one is better than the other depending on the distance at the far end but overall they are pretty much the same
If I compare the vertical to the balun based single wire there are times that again that one is better than the other based on the calling station but overall they are pretty much the same
I can make 50 contacts at POTA and I pretty well work the usual states with their usual signals and at times you notice a pipeline into a state that provides stronger signals
The other night I got a bonus with a Washington station and South Dakota that I needed for my POTA states and I heard them on the inverted vee but not on the vertical. So that was an important lesson that if I was running a vertical mobile antenna or a 17fter with a coil I would have missed these 2 states
Over 9000 contacts and I still need 6 states so the right antenna at the right time is the one that works best
I think 5 radials in place of 2 would also be better with more wire on the ground in each direction
With all that said I still have OCD and ADHD over the antenna, do I have the best one, is that better than this and does the DX spray really work and then one day after 300 contacts in the park I said “This Inverted Vee works like gangbusters”
John VE3IPS
Planning ahead of an activation or summit operation is important and you can choose what antenna you can deploy easily and safely based on the band conditions
A lightweight antenna like the Gabil GRA-7350TC would be handy as well
I think the vertical may be the easiest to deploy once you figure out if its clamped, ground spike or a tripod is used to hold it up
john VE3IPS
SOTA is tough in my area but I am always trying for a POTA to SOTA contact and I have a handful of them
Well, even the balun for a centre-fed dipole will have losses but can be minimised by good construction. You’re right about the Chameleon vertical’s lossy transformer but I find it’s fine with 10W CW on 10MHz and above and use it instead of my EFHWs or CF linked dipoles in strong wind or rain or where the summit topology demands a small antenna footprint.
These are not DX stations, but only local stations in the receive report. The result would be different for DX stations. Local stations have a steep elevation, which a vertical antenna cannot do so well.
73, Peter - HB9PJT
Ultimately, it’s always the same
With cars, they say: nothing can replace displacement other than (more) displacement
And with antennas, it’s wire length or area and height
I’ve noticed for a long time (not just since the Elecraft KH1) that many SOTA activators are using “small” telescopic antennas. There are plenty of “miracle antennas” on the market.
If you’ve sent a spot, you get your QSOs, there are lots of chasers who can compensate for the weaknesses with their good antennas. Unfortunately, that doesn’t always work with an S2S. Especially with groundwave QSOs, I often find that I can hardly hear activators with these small antennas
 and stations with an EFHW give a great signal!
During the 10 m challenge I often used the 6 m Decathon mast and a 5.80 m random wire + 1:9 Unun
 it is a light, inexpensive unit
 and works well from 10 m to 20 m
 at frequencies below it is rather weak.
Indeed good construction is important.
But balun-related losses with a centre-fed dipole are typically low because it is dealing with low impedances, without too much reactance; assuming the dipole is being used on the band for which it is a half-wave.
As we know, the EFHW balun must accommodate a wider range of impedances; higher losses are more likely, but perhaps not always?
73 Dave
How can a 5.8m length of wire be ‘random’. It’s 5.8m. There is nothing random about any length of wire. The wire is either resonant or non resonant and may include some sort of impedance match.
Andrew VK1AD
https://udel.edu/~mm/ham/randomWire/
Déjà vu on Groundhog Day?
Every time someone posts a type-A vs type-B antenna topic we go through the same steps:
  • We discuss some technical aspects of each antenna type
  • Someone posts a load of radiation lobe model diagrams
  • Someone points out that the comparison wasn’t done strictly enough to reach a conclusion (e.g. which type is better)
  • Die-hards / long-in-the-tooth bloggers point out there is no best type from the most-popular 3 or 4 types of antenna that activators use, and that they are ALL pretty good and each type has its strengths and weaknesses
  • Someone will argue [correctly in my opinion] that it depends what you are trying to achieve, e.g. excellent dx or get enough contacts to qualify the summit before your brain and body freezes
  • Someone [like me] will point out there are other factors influencing the choice [if you’re lucky enough to have multiple antenna types for the intended band(s)], like weight, packed volume, speed of deployment & take-down, suitability for a particular summit topology (e.g. small footprint needed), suitability for adverse wx (e.g. strong winds / heavy rain), etc.
  • Finally, someone [@MM0FMF ?] will write “the best antenna is the one you own”
Did I miss a step?
For a few years we used to visit a holiday home on Anglesey (near GW/NW-069) and I set up my rig in our downstairs bedroom. I ran a wire out of the window, round to the front, up and over the roof and along to a high point in the garden (it sloped up). I added a counterpoise and used an ATU to tune it. I have no idea how long the wire was. That’s a random wire.
Unfortunately it’s no longer available as the owner had to sell it due to covid.
Yes, you and some other hams know that antennas like your Chameleon MPAS are a compromise and know that it works well enough. You know you can whip it out and get it up in the cold without problems. Impressive for an older gentleman. I hope to be in your situation one day (you are +10dByears on me) and also need antennas that are quick to deploy that work well enough.
A wire may be random in length or it may be a “random” length. The quotes are important. “Random” wires are anything but random but a carefully chosen length that works by not being a half wave on any of the bands you want to use.
Random? No.
“Random”? Yes. :slight_smile:
c.f. Armin’s link: Telescopic GP Whip vs EFHW. - #11 by DL6GCA
Yes but the ratio of my age to your age is getting smaller every day.
Perhaps the antenna you actually have on a summit rather than back in the car or at home is even better.
I may try more radials, eventually shorter.
For Sota, I first look for my local EU chasers, and S2S, so I consider the NVIS component as an advantage. Of course the more uniform 360 low angle pattern is nicer for dx and I like to have a DX in my log,
my efhw is 12.5m, 40/20/10. yes, less bands than telescopic gp, but my main bands, easier to install than a 20 m wire. And I do not guy the mast, I put my fishing rod into a PVC piece of pipe. Fast, and good enough even in windy conditions.
I agree, I would choose the gp if the objective on the summit is the VK contacts.
the telescopic here is full size 1/4 wave on 20 m and above. For 40 m, no doubt that a13m efhw is shortened 7Mhz efhw, but proportionnaly longer than the 5.7 m telescopic whip,
of course, and my first words of my topic said my efhw is a winner. My post tried then to explain which data I used ro come to my conclusion.
Overall, I apreciate all your comments, Your comments influenced me, for continuing some GP tests, with some more radials, shorter, and with a loading coil for 30/40 m.
THANK YOU all, for your comments.
73 de Pierre F5MOG
My Vertical antenna I use for VKFF is a Hustler mobile loaded vertical with each band coil screw on/off to change bands. I have the antenna base on 40mm pvc pipe 1m long so no interaction with the steal picket I belt in the ground as support. 2 quarter wave radials elevated about 1 metre made like a link dipole for 15/17/20m. To get resonance with the 40m coil I just run the same radial and connect 1 end of the radial wire to my earth side of the antenna. Make sure all links are closed. Works very FB and puts stuff back into use 1 less home for spiders in my shed.
Ian vk5cz
