Hi,
Is there a problem with upload of SWL logs to the database ?
I am asking because in one line of my lastest log I had inadvertently told my logging program that the line was for a SWL report and upon attempting to upload I get a message that no V2 header was found on that line.
I have one separate SWL log that contain just 2 log entries (which I probably created for testing some time ago) and attempting to upload that also give the same error - here is that CSV Log:
Signature,Call (my call),Full Reference (my summit),Date,Time,Band,Mode,Call (his call),Full Reference (his summit),Notes
v2swl,RS108745,26/02/2016,19:35,144MHz,FM,G1AAA/P,G/WB-010,
v2swl,RS108745,26/02/2016,19:37,144MHz,FM,G1BBB/P,G/CE-001,
So is ‘v2swl’ as the line header no longer valid ? (if it has changed what should the SWL format now be).
Stewart G0LGS
