Something doesn’t add up here and I think SOTA is a little biased to the northern hemisphere.
So let me get this straight:
Let’s say we have a summit that’s worth 10 points in the northern hemisphere and it has a road going up almost to the top (its a lookout) but, you have to walk the trail the last 1km or 2). Now being that its a leisurely climb, open fields warm sun and its summer (23 degrees in the sun), you get 10 points for activating.
Now winter comes. So you throw on a jumper and jacket etc to keep warm and go for a walk (or you could use a snowmobile and go to the top and walk the last 20 metres) and somehow you gain an extra 3 points !!! For what!!
Being in the snow!!
Sure it might be cold, but from our end it doesn’t add up. Sure, trying to walk through soft snow is hard work ( I done it when I was younger), but maybe you should try what we do.
Now let’s look at Far North Qld or the tropic regions. Using the same mountain as an example,
For starters,
1/ there is no road or walking trails to 98% of the summits. That means we have to hike from the bottom to the top. Sometimes it may mean crossing several mountains to get to the summit . Overall though, its not an easy stroll. Its damn hard yakka in the jungle.
2/ Now here In winter here its gets to a mild 28 degrees and summer its in the 33-36 degrees. Out west in the outback (we lived out there when I was a miner, it get to around 48 degrees. Things are getting a little warm. In other words, the sweat is pouring out of every orifice in your body
3/ There are no trails. Period. We have to hack our way thru the jungle and this could take a full day just to go up. This means not only are you expending energy walking, but your also expending energy cutting and slogging your way through the vegetation. Beware the lawyer vine and the like, as they want to tear you to shreds as you slug your way thru
3/ Then there’s the heat and humidity. Once you get in there, the temperature goes up by another 10 degrees and the humidity goes up to around 90%. Believe me , its like being being wrapped in a hot wet steamy blanket and there’s no escape. If the wet season is on, it worse. The mozzies and the like are in plague proportions. Believe I know. I do a lot of jungle fishing in there.
And, I can see why the tropic summits haven’t been activated. Its hard work.
So with all this in mind, why is a summit in the north worth an extra 3 points for winter when all your doing is putting on a jumper and jacket?
Just a thought
