Apologies if I missed info concerning this, but with the migration to the new database have we lost the Info ? History is fine but the tips on access, parking approaches in the Info was very useful, hopefully it can be restored.
Dec
ei6fr
Dec
ei6fr
Maybe you can say where you are looking (URL) ?
Hi Andy
I see the same issue, it also appears if you select a single summit
The info link produces this URL
http://www.sota.org.uk/Summit/G/LD-005
to work I think it needs to be:-
http://summits.sota.org.uk/summit/G/LD-005
Note that the 2nd /summit is also case sensitive.
73 de
Andrew G4VFL
Well take for example KIppure EI/IE-005. When I look on the History Tab for this summit I see all previous activations. When I hit the Info tab I get an empty page. On the previous database there was displayed several entries by previous activators of this summit on access, approach etc. as well as the option to add additional notes on the summit. This appears to be the case for several other summits in EI that I quickly checked.
Declan
Magic Andrew. I’ll get that onto the job list, just an old style link that needs to point to the new summits site.
There is a link to that on sota.org.uk and from SW3.
Thanks Andrew & Andy , when I pasted in the new link all points to where it should.
Dec
In the meantime - you can access all Summits data via the Summits website here: https://summits.sota.org.uk/
For example G/LD-005:
