Some great views of the Marilyns. Conachair is on the main island and you can also see the fantastic sea stacks which I’m guessing will be the last Marilyns to be activated in the UK!
If you could only book weather like this for every island visit.
From memory the seastacks are more of a steep walk verging on a scramble rather than a climb. Massochists can of course take the hard route. The hard bit is getting there to start with - then even harder to get to the base of the stacks. Easiest way used to be to join the army ;-))
Conachair is easy but you would need to be a St Kildan to climb the stacks. The Great Skuas dive bomb and more on visitors. Wonderful, I have been, highly recommended if you can stand getting there. when I went one guy had to be prized off the boat after getting hyperthermia
Dont forget you might need special permission from both the army and the national trust for scotland to operate… its a missile firing monitoring station I think.
Robert
GM4GUF
