HG4UK
17 April 2009 01:16
1
Hi all,
the SpotSMS/SpotAPRS gateway seems ready to use.
What are these?
SpotSMS is a gateway between the mobile phone network and the SOTAwatch.org ’s spot list. If you are QRV on a summit just send an SMS to the SpotSMS gateway and it shows up your spot on SOTAwatch.org .
With help of SpotAPRS gateway you will be able to send spot to SOTAwatch.org via European APRS flow.
For more information have a look at the SpotGateway Log site.
Zsolt
HG4UK
M0EIQ
17 April 2009 13:22
2
In reply to HG4UK:
The APRS gateway looks very interesting, however the 2 hour limit for spot-codes is a little short. It may be many hours between an activators last internet access & the time to self spot. Could the time frame be extended? Say 8 - 12 hours?
Secondly, does the gateway only pass one APRS spot per activation, or does it rely on Sotawatch moderators manually removing duplicates? If the latter, I would have doubts about using it for fear of increasing their workload unneccesarily.
All the best,
Dick.
In reply to M0EIQ:
Hi Dick,
One shall generate spot-code in advance, when still at home. You have to specify the estimated time of activation, just like for an alert. The spot-code is valid for that
time in the future. Then program your APRS device with the spot(s) and send the packets when activating.
SpotAPRS has a history of 15 minutes, duplicates within this time are ignored.
This shall reduce the number of eventual duplicates to a tolerable level.
Zoli
M0EIQ
17 April 2009 17:25
4
In reply to HA5CQZ:
Sounds good, Ill give it a try next time I’m out.
Dick.
In reply to HG4UK:
Zsolt,
Are you sure there is no way to use the SpotAPRS from the states? I would love to use SpotAPRS this weekend. I would also like to test SpotSMS.
Tom-N2YTF
In reply to N2YTF:
I added the US traffic, so in principle it shall work now. Give it a try.
Zoli
In reply to HA-friends:
PSE SOME HELP IF POSSIBLE
I have tried several times but always failing … my SMS message is not display on the sotawatch2 … I do something wrong but what … I do not know ?!
I send sms to nr 036703595143
ON6DSL/P LOGIN PW ON/ON-001 7118 IGNORE SMS TEST
Luc ON6DSL
In reply to ON6DSL:
Hi Luc,
Your SMS has not arrived. Please send it to 0036703595143, note the double zero in front of 36.
The text shall look like:
ON6DSL/P PASSWD * ON/ON-001 7118 IGNORE SMS TEST
Note the third word, for a self-spot it must be an asterisk (*). If you spot someone
else then put his/her callsign there.
Zoli
In reply to ON6DSL:
Luc,
Keep at it, with Zoli’s help I was able to use SpotSMS from the states. Very cool!
Tom-N2YTF
In reply to HA5CQZ:
Yes … Zoli it works COOL !!! Mini Tnx
I was forgotten the dubbel 0
Luc ON6DSL
In reply to ON6DSL:
You are welcome.
Zoli
ps: since the spot is sent with your identification, you can also delete it if you wish.
G6SFP
3 May 2009 00:38
12
In reply to HG4UK:
Hi, I used this gateway today when my mobile would not make a data connection.
It worked perfectly…
Thanks for providing the service,
Nigel.
gw6sfp/p
Dear SOTA friends, PSE take notice and for information.
SMS SPOTS NOT ALL ON SOTA WATCH 2
IN SMS SPOTS = OK
IN SOTA WATCH2 = NOK
No. Time (UTC) Source Activator Reference Frequency Mode Comments Sender
1 2009-05-03 15:21 SMS OE/DF9TS/P SOTA OE/NO-181 28.062 MHz CW DF9TS
2 2009-05-03 11:34 SMS ON6DSL/P SOTA ON/ON-016 14.320 MHz SSB qrv ON6DSL/P
3 2009-05-03 11:14 SMS ON6DSL/P SOTA ON/ON-016 7.130 MHz SSB Rudy On4cmt rst 55 here ON6DSL/P
4 2009-05-03 10:16 SMS ON6DSL/P SOTA ON/ON-016 7.130 MHz SSB Qrv ON6DSL/P
5 2009-05-02 22:08 APRS N2YTF SOTA W2/GC-001 28.385 MHz SSB cq N2YTF
6 2009-05-02 22:07 APRS N2YTF SOTA W2/GC-001 28.385 MHz SSB N2YTF
7 2009-05-02 21:56 APRS N2YTF SOTA W2/GC-001 181.175 MHz ?? N2YTF
8 2009-05-02 21:55 APRS N2YTF SOTA W2/GC-001 18.117 MHz SSB cq N2YTF
9 2009-05-02 21:53 APRS N2YTF SOTA W2/GC-001 18.140 MHz SSB N2YTF
10 2009-05-02 21:50 APRS N2YTF SOTA W2/GC-001 5.403 MHz SSB N2YTF
11 2009-05-02 21:37 APRS N2YTF SOTA W2/GC-001 5.403 MHz SSB cq N2YTF
12 2009-05-02 21:25 APRS N2YTF SOTA W2/GC-001 14.000 MHz CW N2YTF
13 2009-05-02 21:24 APRS N2YTF SOTA W2/GC-001 14.353 MHz ?? cq N2YTF
14 2009-05-02 21:22 APRS N2YTF SOTA W2/GC-001 14.350 MHz ?? N2YTF
15 2009-05-02 21:18 APRS N2YTF SOTA W2/GC-001 1.442 MHz ?? N2YTF
LUC ON6DSL
I just tried it. But it doesn’t work here either.
On3wab/p pw * On/On-022 3666 Sms Test.
I sent it to the number mentioned above with the 2 zero’s :o)
Do the letters have to be in capital or is this not necessary?
Peter
G6SFP
3 May 2009 22:39
15
In reply to ON3WAB:
Just a guess, but is it because the sender used was for example on3wab/p rather than on3wab ?.
Nigel. g6sfp
In reply to ON3WAB:
Hi Peter and Luc,
Thanks for the feedback and sorry for the bugs, we are looking into the problem.
Stay tuned…
Zoli
In reply to G6SFP:
Might be Nigel, but if you spot yourself you should put /p I think? Otherwise you should send on3wab once and then on3wab/p agn?
Let the big guys look into it first
Peter
In reply to ON3WAB:
Peter, do you have ON3WAB/P also as a registered callsign?
Zoli
Hi Zoli,
No I haven’t. Registered as ON3WAB
Would Nigel’s remark be the good one?
Peter
