Spot logging easy peezy
By accident today I noted the small square box with a plus sign on each spot when I am logged in.
Having worked the spot, I found that when I tapped on the square the computer had done almost all the logging work making my logging task easy peezy.
David
G0EVV
Its great until you get a busy day and you end up logging a VK or ZL on 10Ghz due to the spots coming in thick n fast :slight_smile:
Its a great feature, I use it all the time these days to upload a chase.
Ian vk5cz ..
Remember to make at least one log via the full database say once per month so that your badges update. If you always log via SOTAwatch the badge update doesn’t get run.
