Hope folks don’t mind me dropping this in here. I just wanted to share some information on a special callsign I applied for from Comreg which was approved today.
I will have the call sign EI0WAAAW for the month of April 2026. This is to mark World Autism Awareness / Acceptance Week from April 1st to 7th (as well as other dates, events etc throughout the month).
I’ve received interest from some experienced groups in EI keen to help me put together a little mini event so hopefully I can get something arranged - if all else fails I will just fly solo and do my best with the gear I have to hand.
Just wanted to get the word out and I hope folks might take part (I believe other callsigns might be set up worldwide too for related events).
More information on my personal blog below, plus a little info behind the QSO/SSTV card image which I have also shared here. Thanks everyone, hopefully hear you on the air soon.
Just an update, I have made a QRZ page for the special call and also provided some more information. EI0WAAAW will operate at a number of dates across April and with multiple operators.
Hello. Just a heads up I’ll be operating at lunch today, circa 1pm to 2pm +/- at POTA IE-0136.
20m SSB at 100w via ATAS/891.
20m SSTV 14.230 at 100w via ATAS/891.
2m FM 145.500 call then QSY.
2m SSTV 144.500 TX 3 times. No RX.
70cm FM 433.500 call then QSY.
70cm SSTV 433.400 TX 3 times. No RX.
SSTV transmit will follow after I work 270 FM. I’ll spot on PoLo and Pota.app site.
Short activation but would love to make QSO’s if possible. If anyone receives the SSTV image I would be absolutely overjoyed to see results if anyone successfully receives it.
Yesterday I made 2 contacts on 2m FM and also transmitted the SSTV image. @EI5KO kindly mentioned he was going to try and capture it so hopefully he was successful.
Thanks all and hope to work some of you today on World Autism Awareness Day, April 2nd.
Just a heads up today is my last day with the license for EI0WAAAW before it expires at midnight.
I know it isn’t SOTA but I will be at POTA IE-0136 later tonight, QRO at 100w ATAS/891 in the Hillman Avenger just for a short time, likely 20m SSB and CW but will call on 270 with the FT65 and RH770 too.
The park closes at 8 sharp so I’ll be gone a bit before then. Hope to catch 10+ contacts for the final time.
I will also TX the SSTV image on 20m 14.230 as well and will spot this in PoLo. If anyone receives the image that would be amazing to know. I can listen for a QSO for a few minutes too with Robot 36.
