No problem posting my alert for tomorrow, but instead of showing my name on a Mouse-over, it reads: Operator: Not Recognized. On SOTAwatch 2 it knew who I was. There must be something more that I need to do to transition over to SOTAwatch 3, but I don’t know what that is…
Hi Dave,
Once logged in SW3, you need to edit your profile and inform your personal data, i.e. name, callsign, alternative callsigns used, etc
However, I’ve seen people still having the not recognised problem even after having filled all data and also having the name ok on spots while still being not recognised on alerts.
A log-off and log back on cycle seemed to solve the problem.
Good luck,
I had the same issue a few months ago and discovered quite by accident that if I edited the alert and saved it again, I was recognized. Now it seems to recognize me on the first try.
Thanks for the suggestions - I tried them all, but nothing seems to have permanently solved the problem. The only thing that worked was K9PM’s suggestion to edit the alert and save again. The alert then showed my name on the mouse-over. Unfortunately, the next time I posted an alert, I was Operator Not Recognized again. No biggie…
