Hi,
it’s 02:44z right now but SW3 is displaying 03:44 UTC. It displays local (NZDST) time correctly
I seem to remember this happened last time Daylight saving time changed?
Geoff ZL3GA
I’ve just looked at the source code, and SW3 passes off all date/time handling to your browser to do the conversion. Either your browser has wrong TZ info, or your actual time and UTC offset is wrong. You may find reloading the page works if the browser has cached your old offset from prior to DST rollover.
Thanks Andrew, the good news is that after a reboot and leaving it for a few hours, it is now correct. may have been a Firefox caching issue as N1MM was displaying the correct UTC time. SOTLAS was correct too.
Geoff ZL3GA
