The band filter on sotawatch appears to do nothing. Whatever band I select it shows me everything. The mode filter works fine.
Works fine for me, this PC is W10Enterprise + Firefox. I went from everything to VHF and all the HF spots disappeared from the list.
Clear your browser cache and try again.
Try also selecting Spots in last hour.
I have,
For Spots it works on Edge but not Chrome.
For Alerts it works fine on both Edge and Chrome.
Chrome? Just say no.
Everything seems to work fine for me on FF on W10 Richard. I can try Edge but then the Oompa-Loompas in IT will see me doing stuff so I try that later when I get āhomeā. Iāll confirm it works on FF and Brave on Linux.
Ah, I have Brave on my Android phone and it works fine there as well.
For me is working on Chrome+Win7
All works fine with Chrome on my android.
Iāve also tried it with Firefox on Linux and Chrome on Android. It doesnāt work with those either.
It works when you select āLatest 10 spotsā but not when you select āSpots in last hourā.
I wonder if you have something else enabled in the settings that is interfering/overriding your settings.
Make sure everything is set to default and try again.
Iāve just tried a Firefox private browsing window and gone to SOTAwatch3. In the bands filter I selected just 20m and it has shown just 20m spots. If I then change ālatest 50 spotsā to āspots in the last hourā it then shows spots from every band.
In that private window in a browser I donāt usually use Iām not logged in so I canāt see it can be anything in my settings.
So when you are not logged in, everything is working. When you are logged in, there is something not working. So itās something in your account being applied that causes a problem.
No, itās not working. Unless you are saying that āSpots in the last hourā overrides the band setting. It doesnāt override the mode setting.
Confirmed here on latest Chrome. If you select ālatest 50 spotsā the band filter works. If you select āspots in last hourā it doesnāt work. Doesnāt matter if I am logged in or not. Probably some dodgy soldering in the band filter ![]()
All working FB on Brave.
Having installed Brave browser on my PCs, tablet and phone, Iām NEVER going back to nonsense like Chrome or IE. Was never a fan of FF personally, but I am a big fan of Brave - fingers crossed it continues being all the things I like about it.
Does the same thing on Safari. Itās a bug⦠I will file a report.
Iām getting a heavy ādeja vuā feeling to this. Iām sure weāve had it before. Or something very similar.
Using Chrome on Android while logged on it works if I choose one of āthe last X spotsā choices. It doesnāt work if I choose a time period.
Yep, and that is exactly what I put in the bug report. Thanks.
