Dear all,
SOTAtracker is my personal build of GridTracker, and it has become my go-to tool for summit chasing over the past six months. Maybe it is of interest to you too.
If you would like more detail on what this build does, have a look at the quick-start guide here:
If you want to try it yourself, you can find the installer (Windows only) below. Please have your chaser/activator log at hand to get the most out of it. Download it before installation from
sotadata.org.uk: Login, then
Logs - Chaser - Download Complete Log, and if applicable
Logs - Activator - Download Complete Log. Remember where you saved them. You will be asked for them during installation (check the guide!).
This is a beta build, and it stops working end of September 2026. It connects to the Spothole API and the SOTA cluster to retrieve real-time activation data. The purpose of the time limit is simply to avoid long-term issues on those nodes, should something go wrong. If no issues are reported, the restriction will be lifted and a new release provided.
If you run into any issues, please share them here.
One final but important note: It is a private build, heavily AI supported. No warranty, no liability, use it at your own risk.
73, Matt
