sotagoat alerts crashes sotagoat
Sotagoat has started crashing/exiting when alerts is selected. I hadn’t been using it for a while but noticed the problem yesterday. Anyone else having this problem? Is there a workaround? I will be using sotl.as in the meantime but prefer to keep safari available for other purposes.
Oh, on iPhone 15 Pro 256
Allan K7GT southern Oregon
Yes same here, I assumed it was because I use an iPhone 6s, rather old kit now.
Same reason I assume, why I can’t call up the database on my phone & also why, possibly, the points value of each hill doesn’t show on my Sotawatch screen.
Edited-alerts now working for me also. Thanks for sorting this out. 73 John
and
Hi folks! I am working on implementing the new API… should be fixed today. I only just found out about the changes yesterday.
Update: most of the functionality has been restored. The only thing not currently working is the ability to edit your own spots, and I’ll continue to work on that.
Working now.
Thanks Rockwell for restoring the push notifications, I was missing Rooster :slightly_smiling_face:
SOTA Goat is the best IOS app for receiving & posting spots and posting alerts.
Andrew VK1AD
Thanks Rockwell for restoring the apps functionality on such short notice. I’m sure you know that your app has a strong following even though there are other options available.
Quinton NU7Y
I posted a spot today with SOTAGoat, but it ended up showing as TEST on the SOTAWatch website. It was a 145.500 FM spot.
Although perhaps it didn’t work as I put in 145.5 as the frequency and not 145.500?
I’m seeing a lot of test spots right now from some W4V folks… makes me wonder if they are using SOTA Goat.
Looks like something is broken… when I look at spots in SOTA Goat, they look ok but on SOTAWatch they are all test spots.
Yes probably the case. It shows fine in the app, which is why I only noticed when I got home.
Best to use sotawatch or sotlas website for now.
This should be sorted soon… I alerted @WW1X yesterday and he just replied.
Hi Rockwell @WW1X this morning VK time, SOTA Goat is now crashing when I select Spots.
Andrew VK1AD
All fixed! The TEST issue from earlier, and the crashing Spots tab today. Still ironing out the kinks with the API changes.
I have the same problem on my iPhone 16 pro max
