SOTAcat Troubleshooting help
Hi there, just finished up a SOTACat v.03 by K5EM and am having some issues getting it to work. I am able to connect it via the webpage, and it creates a hotspot. However, it throws errors in the log and then eventually goes to sleep/powers down. I’m going to assume that I probably made an error soldering, as I am not the greatest at surface mount, but was wondering if there was perhaps some helpful troubleshooting steps I could perform to see where I went wrong? Below is the data log:
I (29395) sc:kx_radio: no response received for baud rate 19200
I (29895) sc:kx_radio: no response received for baud rate 9600
I (30395) sc:kx_radio: no response received for baud rate 4800
I (30895) sc:kx_radio: no response received for baud rate 38400
I (31395) sc:kx_radio: no response received for baud rate 19200
I (31895) sc:kx_radio: no response received for baud rate 9600
I (32395) sc:kx_radio: no response received for baud rate 4800
I (32895) sc:kx_radio: no response received for baud rate 38400
I (33395) sc:kx_radio: no response received for baud rate 19200
I (33455) sc:wifi…: Attempting SSID:ham-hotspot
I (33455) sc:wifi…: Station configuration set to access AP SSID:ham-hotspot
I (33455) sc:wifi…: Attempting connection to SSID: ham-hotspot
I (33895) sc:kx_radio: no response received for baud rate 9600
I (34395) sc:kx_radio: no response received for baud rate 4800
I (34895) sc:kx_radio: no response received for baud rate 38400
I (35395) sc:kx_radio: no response received for baud rate 19200
I (35895) sc:kx_radio: no response received for baud rate 9600
I (36285) sc:wifi…: WIFI_EVENT_STA_DISCONNECTED
I (36285) sc:wifi…: Retrying connection to SSID…
I (36395) sc:kx_radio: no response received for baud rate 4800
I (36895) sc:kx_radio: no response received for baud rate 38400
I (37395) sc:kx_radio: no response received for baud rate 19200
I (37895) sc:kx_radio: no response received for baud rate 9600
I (38395) sc:kx_radio: no response received for baud rate 4800
I (38735) sc:wifi…: Connection attempt failed or timed out. Will try next SSID.
I (38895) sc:kx_radio: no response received for baud rate 38400
I (39395) sc:kx_radio: no response received for baud rate 19200
I (39895) sc:kx_radio: no response received for baud rate 9600
I (40395) sc:kx_radio: no response received for baud rate 4800
I (40895) sc:kx_radio: no response received for baud rate 38400
I (40965) wifi:new:<1,0>, old:<1,1>, ap:<1,1>, sta:<0,0>, prof:1
I (40975) wifi:station: 52:4d:bb:3d:fd:d0 join, AID=1, bgn, 20
I (40985) sc:wifi…: Station 52:4d:bb:3d:fd:d0 connected, aid=1
I (41175) wifi:idx:2 (ifx:1, 52:4d:bb:3d:fd:d0), tid:0, ssn:0, winSize:64
I (41395) sc:kx_radio: no response received for baud rate 19200
I (41495) esp_netif_lwip: DHCP server assigned IP to a client, IP is: 192.168.4.2
I (41895) sc:kx_radio: no response received for baud rate 9600
I (42395) sc:kx_radio: no response received for baud rate 4800
I (42895) sc:kx_radio: no response received for baud rate 38400
I (43395) sc:kx_radio: no response received for baud rate 19200
I (43895) sc:kx_radio: no response received for baud rate 9600
I (44395) sc:kx_radio: no response received for baud rate 4800
W (44725) wifi:Haven’t to connect to a suitable AP now!
W (44725) sc:wifi…: Failed to get AP info, error: ESP_ERR_WIFI_NOT_CONNECT
I (44725) sc:wifi…: Reconnection attempt initiated
I (44725) sc:wifi…: Initial connection established, setup task notified
E (44725) smbus: I2C no slave ACK
E (44725) sc:max17260: No device found at address 0x36
I (44725) sc:batmon…: battery: 3.92V 65.78%
I (44725) sc:batmon…: Free heap: 194692
I (44725) sc:setup…: battery_monitor task started.
I (44725) sc:setup…: wifi initialized.
I (44725) sc:webserve: defined webserver callbacks.
I (44725) sc:setup…: webserver initialized.
I (44895) sc:kx_radio: no response received for baud rate 38400
I (45395) sc:kx_radio: no response received for baud rate 19200
I (45895) sc:kx_radio: no response received for baud rate 9600
I (46395) sc:kx_radio: no response received for baud rate 4800
I (46895) sc:kx_radio: no response received for baud rate 38400
I (47395) sc:kx_radio: no response received for baud rate 19200
I (47555) sc:wifi…: WIFI_EVENT_STA_DISCONNECTED
I (47555) sc:wifi…: Retrying connection to SSID…
I (47695) sc:wifi…: All connections lost
I (47895) sc:kx_radio: no response received for baud rate 9600
I (48395) sc:kx_radio: no response received for baud rate 4800
I (48895) sc:kx_radio: no response received for baud rate 38400
I (49395) sc:kx_radio: no response received for baud rate 19200
I (49725) sc:batmon…: Free heap: 186196
I (49895) sc:kx_radio: no response received for baud rate 9600
I (50385) sc:wifi…: WIFI_EVENT_STA_DISCONNECTED
I (50385) sc:wifi…: Retrying connection to SSID…
I (50395) sc:kx_radio: no response received for baud rate 4800
I (50895) sc:kx_radio: no response received for baud rate 38400
I (51395) sc:kx_radio: no response received for baud rate 19200
I (51895) sc:kx_radio: no response received for baud rate 9600
I (52395) sc:kx_radio: no response received for baud rate 4800
I (52895) sc:kx_radio: no response received for baud rate 38400
I (52975) sc:wifi…: Attempting SSID:ham-hotspot
I (52975) sc:wifi…: Station configuration set to access AP SSID:ham-hotspot
I (52975) sc:wifi…: Attempting connection to SSID: ham-hotspot
I (53395) sc:kx_radio: no response received for baud rate 19200
I (53895) sc:kx_radio: no response received for baud rate 9600
I (54395) sc:kx_radio: no response received for baud rate 4800
I (54725) sc:batmon…: Free heap: 186196
I (54895) sc:kx_radio: no response received for baud rate 38400
I (55395) sc:kx_radio: no response received for baud rate 19200
I (55805) sc:wifi…: WIFI_EVENT_STA_DISCONNECTED
I (55805) sc:wifi…: Retrying connection to SSID…
I (55895) sc:kx_radio: no response received for baud rate 9600
I (56395) sc:kx_radio: no response received for baud rate 4800
I (56895) sc:kx_radio: no response received for baud rate 38400
I (57395) sc:kx_radio: no response received for baud rate 19200
I (57895) sc:kx_radio: no response received for baud rate 9600
I (58255) sc:wifi…: Connection attempt failed or timed out. Will try next SSID.
I (58395) sc:kx_radio: no response received for baud rate 4800
I (58895) sc:kx_radio: no response received for baud rate 38400
I (59395) sc:kx_radio: no response received for baud rate 19200
I (59725) sc:batmon…: Free heap: 186232
I (59895) sc:kx_radio: no response received for baud rate 9600
I (60225) sc:setup…: Startup watchdog timer expired, and battery not charged; shutting down.
I (60225) sc:sleep…: preparing for deep sleep:
I (60225) wifi:station: 52:4d:bb:3d:fd:d0 leave, AID = 1, bss_flags is 658531, bss:0x3fcafe48
I (60225) wifi:new:<1,0>, old:<1,0>, ap:<1,1>, sta:<0,0>, prof:1
I (60225) wifi:idx:2, tid:0
I (60225) sc:wifi…: WIFI_EVENT_STA_STOP
I (60225) sc:wifi…: Station 52:4d:bb:3d:fd:d0 disconnected, AID=1
I (60225) sc:wifi…: WIFI_EVENT_AP_STOP
I (60295) wifi:flush txq
I (60295) wifi:stop sw txq
I (60295) wifi:lmac stop hw txq
I (60295) sc:sleep…: wifi is stopped.
I (60295) sc:setupadc: adc deregister curve fitting calibration scheme
I (60295) sc:sleep…: adc is shutdown.
I (60295) sc:sleep…: all gpio pins off and isolated.
I (60295) sc:sleep…: entering deep sleep…
I (60295) sc:sleep…: goodnight!
Terminal disconnected: NetworkError: The device has been lost.
Appreciate your time!
Ryan de NN6RF
Update: Ok I feel pretty silly, I realized after I found a youtube video that I needed it plugged into the radio for it to stay on.
An issue I seem to have though is that a battery connected to the JST connector appears to not be seen as having a charge, I could still use some suggestions. The unit works with USB connected, but does not power up on its own with just a battery.
Battery out of charge?
In order to charge, apply power to the USB-C and make sure that the SOTAcat is switched ON. Ironically, it doesn’t charge when the power switch is OFF.
Jeff KC6X
