I am looking to make a Low Pass Filter for a 2M project I am working on, It is a design by OZ4HZ and I can source most of the components except the board for which I don’t have the PCB design files. I asked around and someone said to me “Don’t you have a Sotabeams 2M Band Pass Filter”, well yes I do but isn’t a Band Pass Filter for receive only, it’s not an LPF.
The SOTABEAMS filter is rated at 5W for transmit - so works with handhelds… If this is useful. Paul (Well 2W continuous but 5W with a 30% duty cycle…)
I just assumed it was really for receive, I knew about 5W transmit, but it’s not something I use a lot tbh only at Bardon Hill and even then it doesn’t get rid of the Pager interference. Also, the cost is prohibitive, far cheaper to build
There is this one, but it is still £30 not including postage https://www.dxworld-e.com/product-page/lpf-filter-vhf-2m-band-600w
A bandpass filter makes more sense, especially for reception. It also cuts out the lower frequencies that cause blocking.
A low-pass filter is more likely to be used to suppress the harmonics that are emitted.
Yes, that was how I understood it, I need a LPF because I am using Chinese Micro Transceivers, and need to get the harmonics down to an acceptable level, the actual output level is only going to be between 1 and 4W
According to the data from OZ4HZ, such a filter can be built quickly… you don’t need a special PCB. It only carries components and provides a good ground connection…
This can be checked quickly with a NanoVNA, for example.
A Bandpass filter is both a Hi-pass and a low-pass with an overlap in the middle so it PASSes the signals in-BAND
If you build a filter and it doesn’t fit into the TRX itself… then of course you should also have good sockets and an RF-tight housing. If you have to buy everything… the price difference to a ready made available filter will not be that high… building it yourself is often no worth it in terms of price… but you can learn a lot!
Received an email this morning and I can’t order the coils because the UK distributor will only sell them in batches of 1500 so it looks like I will be spending about £30 for one from DX world
