Hi all,
Early this morning, S50TD and I returned home to our QTH from Ireland (EI). Here are a few notes and tips that might be helpful to other travelers planning a SOTA activation in EI.
Car rental at Dublin Airport:
We flew from Zagreb to Dublin. Because our flight was delayed, we landed late and found out that car rentals at Dublin Airport only operate until 1 AM. As a result, we had to “sleep” on the airport floor until 5 AM. If you find yourself in a similar situation, Terminal 2 (2nd floor, near the Multi-Faith Prayer Room, which was unfortunately closed) is a decent spot. Also, do not forget to take photos of the entire car interior and exterior before driving off.
An integrated antenna tuner is highly appreciated:
Due to severe winds — estimated at over 70 km/h on EI/IE-003 — we were usually forced to use a shortened, non-resonant antenna. The built-in tuner in the X6100 absolutely saved the day.
Anchor ropes and pegs:
Even a shortened vertical antenna needs to be anchored properly in high winds. Try practicing your anchoring setup at home before you leave. Some hills have rocks or natural features to tie your ropes to, but on EI/IE-018, we had to use tent pegs.
Wind shelter or headphones:
To hear your correspondents over the roaring wind, you will either need good headphones or, if you are operating in a 2-op mode, a proper wind shelter. We learned this the hard way on EI/IE-052, where we spent half an hour unable to make a single QSO until we finally moved into the lee side of the ridge. On EI/IE-003, HB9DGV managed to find a much better-sheltered spot than we did!
Rain ponchos are useless:
If I had used a rain poncho on EI/IE-003, I probably would have been blown all the way to Wales, despite my 90 kg weight! Stick to a high-quality waterproof jacket and trousers to minimize wind resistance.
Weather is highly changeable:
Do not rely on weather forecasts a week in advance. Take it day by day and adjust your plans every morning. A huge thank you to our XYLs, who were incredibly patient with our activation schedule changed from day to day.
Last but not least:
Be sure to ask on the SOTA Reflector about the specific summits you plan to visit in EI. Our Irish colleagues are extremely friendly and eager to help. Thank you to everyone who helped us, especially EI6FR for the detailed email filled with invaluable hints on how to approach the summits.
73 de (IE/)S57VV, Primož
