As mentioned in the minutes of the SOTA MT meeting, each group will be posting our priorities for 2017. As the newly elected leader of the IT Group, it falls upon me to provide our list of priorities for 2017. My aim is not to go into great detail on all of these, but to give a sense of what it is we are working on, approximate timelines, and some of the challenges we face.
For context, the IT group within the SOTA MT consists of three permanent members: myself as leader, Jon GM4ZFZ and Andy MM0FMF. Obviously, Jon is primarily focused on the website, and Andy primarily on the database. We will be assisted as needed by Csaba YO6PIF, and Cristophe ON6ZQ
Business Continuity
Our first primary priority is to ensure we have suitable Business Continuity plans in place to ensure SOTA can continue to run. Unfortunately, we have seen this occur with the sad passing of Eric KU6J, who maintained the RBNGate software; an event that has prompted substantial discussions within the MT about how we keep the lights on in the event of another unfortunate event of that magnitude.
There are two aspects to Business Continuity Planning: the first, obvious, one, is that backups (or more precisely, means of recovery) of critical systems must be kept, but this alone is not enough. These backups need to be tested and deployed by others who are not the primary maintainer of the system, who may be incapacitated and unable to assist with recovery. The latter aspect is the area we currently require further work on, and we have a number of initiatives underway to ensure that the entire IT group can manage any other system, and have experience with bringing up these systems.
We anticipate that we will have a reasonable amount of this in place within the next month or two. Itâs easy to describe, but there are many layers of complexity to deal with. This is our number one priority at this point, overriding other large activities that are ongoing.
SOTA Shop Integration
Currently, the SOTA Shop is a separate website, with no real links back into the rest of the SOTA Infrastructure. This leads to a number of challenges for Barry GM4TOE in processing of awards. Jon will be overseeing the integration of the shop into the sota.org.uk website, which will allow a better user experience not only for customers, but for Barry as well!
We anticipate this will take between 3 and 6 months to implement. We are currently in the requirements phase, and should be able to move into implementation comparatively soon.
SOTA Maps Integration
Rob DM1CM has expended a tremendous amount of time and effort, as well as his own money, on managing and maintaining the SOTAMaps service. The SOTA MT acknowledges the tremendous value this provides to the SOTA community, and the cost that Rob has borne to keep this service running. I have been working with Rob on bringing the SOTAMaps service onto MT managed-and-paid-for servers, to reduce the financial cost to Rob, and also to ensure the service can continue for the community should anything happen to Rob.
We have one or two action items to go before that transition happens, which are currently stuck behind the higher Business Continuity requirements for all-of-SOTA, but we anticipate doing the cutover within a month or two. Rob will continue to have access to the servers and will continue to maintain SOTAMaps - this is primarily just a change in server arrangements and funding.
SOTAWatch replacement
Jon continues to work on a replacement for SOTAwatch that is integrated into the main SOTA website. There is no timeline at this point for this to be implemented, but we anticipate it will be released before the end of the year.
Database Improvements
A number of improvements are needed for the database environment, primarily in support of other SOTA IT Group initiatives. The first is around the backend work required to enable the SOTA Shop integration and reduce the workload on Barry, the second is decoupling the web interface from the database itself via an API, and the third is providing the infrastructure to enable ARM auto-generation.
Andy will be very busy over the next year, as these are each, in and of itself, a large body of work, as well as the other ongoing database management requirements! Both Jon and I will help out as necessary to alleviate the workload as time permits.
Single Sign On
I will be working as well on providing a Single Sign On solution, to eliminate the tedious need to have separate passwords for SOTAwatch, sotadata, sota.org.uk, the reflector, etc. This will also allow external apps, with some extra work, to determine your identity easily, without having to share passwords with the app, allowing, eg, for upload of log data. This one requires a lot of careful thought, as a failure in a single sign on application would prevent logging in to any application. A multi-redundant cluster will be deployed to allow a strong level of resilience.
SSL Everywhere
An easier one to round out the year, we intend to have SSL enabled on all systems that we run as part of SOTA.
Other work in the work queue, but not prioritised
New association uploads - The number of associations continues to grow, as does the number of summits in existing associations.
Uploader hardening - Increasing the existing number of checks that ensure when uploads do occur, they are correct.
SOTA API - The SOTA API requires ongoing work to deliver all of the API endpoints discussed.
HTML handling - There is inconsistent handling of UTF-8 and other non-UTF character sets that have found their way into things like summits pages.
Summit surveying workflow tools - As part of some of the bigger associations weâve brought online recently, we have been experimenting with a few tools to help facilitate the process. It would be ideal if we can rewrite the current duct-tape-and-wire version with something more extensible.
It is important to note that several of these projects, if implemented in âthe real worldâ, would take several weeks or months of full-time work. For giggles, I handed a rough outline to one of my colleagues, who is a Service Delivery Manager used to quoting these out for consulting projects. She reckoned about 6 months full time to do it all properly, priced in the low six figures. We are not full-time workers for SOTA, nor do we have that amount of funding available, so we wonât get it all done in 6 months, but weâll make a fair whack of an impact on these over the next year.
Cheers,
Andrew
SOTA MT IT Group Leader
