There’s a small update to the Range page in the SOTA Mapping Project, to include a new “Measure” tool to measure distances between various reference points. Points can be SOTA summits, address/city/feature, lat-long pairs, locator, or any combination of these. If the “Measure” control doesn’t appear on the map, just refresh the page to load the new features. Hope this will be useful to someone out there,
really a great tool to calculate the distance between summit to summit contacts.
I just played a little bit with this new feature and tried to calculate the distance for two recent S2S contacts:
DL/MF-071 and DL/MF-079 displays 5427.893 kilometers
OE/TI-358 and EA8/LA-004 gives 5362.389 kilometers
While the second calculation seems to be correct, the first result should be not in kilometers but in meters.
Hope this information helps.
Many thanks for providing this helpful mapping tool.
1st Update: Just calculated the distance for the second S2S with the built-in distance-measurement tool of google maps and this gives me about 3100 kilometers.
2nd Update: I tried again at 22:15UTC and now the calculations seems to be
reasonable:
DL/MF-071 and DL/MF-079 displays 2.787 kilometers
OE/TI-358 and EA8/LA-004 gives 3032.989 kilometers
Another small update - a new tool to generate KML or GPX files from the SOTA / mapping data. Refresh the “Main” page in the SOTA Mapping Project, and a “Tools” control should appear at the top of the map. Click and play!
I left the summit dropdown disabled because I didn’t think anyone would want a GPX or KML file with just one summit. However, I’ve now enabled it for those who might wish to do so.
Also now included is the ability to download KML data either as a direct file download, or as a Network Link. The latter allows the user to have the data streamed from the web into Google Earth, and to be refreshed from within Google Earth - in that way, the data can be kept as up-to-date as the original data sources themselves.
In the Main page, there is a new Search function to search for summits worldwide by name - wildcards can be used here. Look for the “Search…” button
In the Range page, summits found within xxx kilometers/miles now listed in the LH Tools Bar - click on an entry to jump to that summit.
Tables in the LH Toolbars in those two pages are now sortable, on Summit Code, Summit Name, distance, points, etc.: just click on a table header to re-sort.
Improved look and feel of Infoboxes and tooltips all round.
Yes, to add to David’s comment - thank you Rob for your efforts on the mapping project. Like Roy’s (SOTA News Editor)intray at the end of the month mine has been overflowing for the last month. As soon as I can get on top of it though this month, I’ll be uploading some more of my GPX tracks into the mapping database.
I’m planning a trip to S5 Slovenia next summer at the moment for my walking group and a few SOTA pals. Using the range function in SOTA Mapping makes it really easy to establish where we ought to go.
I saw this a few days back when testing with Rob. It was something I had wanted to do for ages but never had the time. I think it’s wonderful to see where your QSO partners are on the map.
As Rob says, this is test data, I think it’s Sep 2013 to mid-December 2013 and it doesn’t include S2S contacts.
Actually there are quite a few S2S QSOs in the activations data: as you’ve hinted, the data are from real SOTA activations from September to mid-December 2013 for evaluation/burn-in purposes…
I just tried the activations test page, it looks very good
The chaser data is from QRZ.com. I can tell as some chasers don’t have their Grid Square details entered in QRZ.com, they appear on the map as the default location for VK, which is right in the centre of Australia near Alice Springs… Otherwise map data looks accurate, even shows the odd S2S.
Registered twice last night & received a message to verify had been sent to my email address - nothing received.
Could it be a browser problem, I was on my kindle fire hdx using silk browser. I have noticed the drop down menus on the database dont drop down on this setup so I cant enter activations when away from home.
Hi Steve, I also registered twice last night as the first didn’t work correctly. Second time I made sure everything was the same case and it worked fine. My error was my callsign, I registered with 2m0ncm but the system only seems to work uppercase.
Hope that helps some of your query - not got a Kindle.
