Is SOTA Goat available on Android? Was it ever or will it be in the future? Right now I use Sota Spotter on my Android but just wanted to try something different.
Tnx
Tim - K5DEZ
Negative. On Android, I recommend VK port-a-log by Peter VK3ZPF. Most excellent app for activating!
-J
Just got another update Today… now I’m on version 1.4.1.
LOVE the ability to tap summit coordinates to copy them!!! Very nice
Thank you Rockwell!
Great stuff! Thank you for the rerelease and the quick update
@WW1X thank you for the new version 1.4.1 which also solves the issue with the “jumping” pages.
There is still a minor issue:
On a summit page of SOTA Goat the date of the “Last Activation” is always one day before the actual date that is shown on the summits page of SOTAwatch3.
Example F/AB-001 Mont Blanc: SOTA Goat shows 23.08.16 as the date of the last activation whereas SOTAwatch3 shows 24.08.16.
Probably a time zone thing. Will take a look, thanks.
Rockwell
Thanks for the map scale in version 1.4.1.
73 Tonnie de PA9CW
thank you!!!
Your work is really appreciated.
Thanks and 73 de VA2EO (Éric)
The version I installed is named Version 3 in the page reached using Settings > About.
Does each country’s app store number the versions differently? Anyway other users in VK will presumably also find they are receiving v3, not 1.4.1
No, the first version he released a couple days ago said ‘Version 3’. The latest one that just came out Today switched to 1.4.1.
Ah, that explains it! Thanks
Have not had a chance to play with it, just downloaded it now.
Thanks Rockwell
Thanks Rockwell
It works, I just tested, spot is sent.
Great !
73, Jarek
Yea for SOTA Goat! Yea for Rockwell! Thank You!!
73, Dave AE9Q
Great, thank you just bought. Is it still possible to recognize the location automatically? So a button where you press it and then it shows your own location. A log function would of course be perfect … I would also pay for it of course
If you go to the map view, then tap the Options in the top-right, you can choose to show your location on the map. Is that what you meant?
yes, thanks, now it works. The first time I flipped the switch, I didn’t see the location. But today after I restart the app, I see it.
Thanks for the SOTA Goat revival. I can hear the goat. However in the past we heard the goat every time there was a new spot. Can that be put back in?
73, Hans PB2T
