It certainly can be possible from summits with good VHF takeoff. For example I used a similar setup on Waun Fach, GW/SW-002 on a Saturday afternoon recently and had 11 QSOs in quick succession ( 2 were S2Ss). I’ve had similar success from Pen y Fan, GW/SW-001.
I have also mistakenly tried to the do the same thing when Wales are playing in the Six Nations. Never seem to have the same results for some reason…
Ok - I’ll have a look at the map. Looking for summits joined by green lines (if they’re accessible by bridleway, there should be no problems/restrictions by MTB).
I can remember reading somewhere that typically these would be started up and before the engines had warmed up they would open the throttles and get up and moving. Bearing life was not considered important if a plane from the other side was coming in for a strafing run with 20mm cannon and 7.92mm machine guns as large holes all over the boat would spoil your day a lot more and quicker than heavy oil consumption and knocking main bearings.
That one in the picture, MTB102 was a prototype with 3x 57L W18 petrol engines. For those of us in the UK of a certain age, just think how many Green Shield Stamps you’d get when you filled up the petrol tanks on that baby
I’ll get in before the pedants. It’s not, which is why I’ve activated USA and Cypriot summits by car.
Your station has to be portable, not powered by or touching your vehicle. Land owner permission is required, unless a vehicular right of way crosses the AZ.
If you’re training you probably want a non e-bike?
There’s quite a few summits I think you could qualify on 2/70 if you ride to to the bottom and walk up (in MTB shoes) and do it on a nice weekend when lots of people are either out activating or chasing, and if you have patience to wait for the contacts to come.
GW/SW-013 and GW/SW-008 (maybe on the same trip) for example.
In the summer, you could also try activating during the 2m FMAC on the first Tuesday evening of the month (70cm is the second Tuesday evening).
If you can carry something to support a slim jim that will improve your chances. Maybe one of those fibreglass tent poles with elastic inside? I found the Sotabeams travel pole pretty uncomfortable to carry in a backpack on a bike and couldn’t find a way to transport it attached to the bike.
At some events, e-MTBs are allowed… they’re timed in a different class, but that doesn’t stop them getting in the way (passing you on the up, but procrastinating on the descents). Quite annoying!
I don’t think I’ll be carrying a pole - nowhere to put it on a FS bike realistically (not on a small frame anyway)… my 2m flowerpot is very good (at least as good as the RH770) but it needs supporting somehow.
I use a Camelbak Hawg NV, it can comfortably holds my Xiegu 6100 and Carbon 6 pole inside the pack. I have managed to strap a Decathlon travel 6m pole to the outside of the pack but wasn’t keen on that.
The extra weight requires more air on my FS setup and I definitely regretted not been on my ebike in whilst Ireland last year
Just to be pendantic a legal e-bike is classed as pedal cycle and needs to be peddled, although you can get up to 250w of assistance, upto a maximum of 15.5mph.
There are a lot of illegal e-bikes that are really electric motorcycles clouding the general opinion or legitimate e-bikes, although the press stil incorrectly likes to call these e-bikes
