There is a network problem with the datacentre in Iceland that houses the SOTA cluster and the SMS spotter. This started at 17:07 10/10/2024. I will post any updates as soon as I get them. Or you will realise it is fixed because the services become available again!
And of course, as soon as I point out there is a problem then the issue gets resolved. ![]()
Thanks for the info Andy, when I came back in I was disconnected. Reconnected and at 19z you have lots of users. Around this time of the evening I normally sign out, will keep my connection on until bedtime tonight methinks. .
73 Phil G4OBK
Look out for a 160m spot later from G4YSS/P who is on G/NP-010 tonight in a tent in freezing temperatures…
I guess around 2130z onwards when the 6m AC Contest concludes…
73 Phil G4OBK
