sota bush hat
what is the size of the hat as it say one size please
Well, it fits my big head.
If I remember when I get back from vacation I will measure one
ISTR they are “One size fits all” hence the album and there is an adjuster to tighten them up if it’s too loose.
it has to be 61 cm or it no good for me
With you there (right down to the size 61)
From experience with hats one size fits all === one size doesn’t fit me!
Maybe SOTA hats will cater for big-heads like us!
Never buy one size fits all clothing of any type as they never fit me.
Regards, Wal VK2WP
I could almost guarantee the fit of the baseball caps. They are one size with a back adjuster and to fit my big head the adjuster was just about minimum size.
Guess fully out it would fit a bowling ball with space to go
61cm is only a UK 7 1/2 size hat which is classed as the small end of XL. The normal (for various definitions of normal) range of head circumferences is 56-61cm so 61cm is a size in the normal range of sizes catered for anyway.
For example I’m a UK 7 1/4 which is 59cm. If we consider head radius for that sized circumference then a 59cm head has a 9.39cm radius and a 61cm head has 9.71cm, a difference of 3.2mm so hardly Earth shattering.
My Decathalon Bush Hat is a one-size-fits-all (as are my Po-Jamas!) and it’s a loose fit unless I pull the adjuster quite a bit to tighten it. You are right to query the size but I would be quietly confident the SOTA hat would fit you.
It is described as “One size fits Most - 60cm”
Perhaps on the neat side for you
Well if it fits at all it will be tight.
Maybe you’d be better off by buying a Decathlon hat, mine is marked 62cm and has an adjuster to tighten it up. Then all you need is to buy a SOTA patch and sew that on yourself.
