Hi folks. I know that a few of you like using APRS out on the hills. I will be setting up a digipeater that should give coverage to quite a number of SOTA Summits. Its callsign is MB7VK and it will be located at a high site in Over Alderley Cheshire. Unfortunately, the site has no power, so for a start it will be on sporadically. I hope to get some solar power sorted out if there appears to be a demand for the digipeater. The plot shows LOS from the site so the radio coverage will be better.
Yes that’s right. I might well apply to change my home iGate to a full two way APRS station although APRS messaging is as naf as it gets.
I should add that while it’s a bit temporary, feel free to email me if you need the service and I can ensure that it is deployed. Probably will not matter until after April 12th of course.
This is MB7VK in operation today. It’s received some packets from over 100 miles away. So there must be a lift on. It will be a lot higher once I get it sorted out.
I have just upgraded my digipeater to the PLXdigi from Microsat. My Argent Data Systems Tracker 4 was far too unreliable. MB7VK should cover most of the higher points in Wales and the Welsh Borders. No progress on the solar yet so it will be rather temporary.
I have deployed the digipeater today (Saturday). I would encourage anyone with APRS in the G/WB, GW/NW and GW/MW areas to try it. I would like to see what coverage it gives. At the moment it can only receive data, however in the next week or so I will implement two-way messaging.
MB7VK is now a very sophisticated system as you can see.
