“Recommendation T/R 61-01” issued by the CEPT ECC (Electronic Communications Committee) , Section 2 “Conditions of Utilisation”, Subsection 2.3:
"When transmitting in the visited country the licence holder must use his national call sign preceded by the call sign prefix of the visited country as indicated in ANNEX 2: and ANNEX 4:. The call sign prefix and the national call sign must be separated by the character “/†(telegraphy) or the word “stroke†(telephony)."
In a related thought… why do stations sign /p when they are portable in a different country. For example… SM/K9EZ/p? Is that required in some countries? All countries I have operated from I just used the portable country prefix, unless of course I had an assigned call.
Maybe. Though the fact you sign SM/K9EZ should be enough to indicate you are not where the callsign is registered. You need to check the CEPT regulations that Rob indicated and also if the local authorities have some extra rules.
Short answer - YES
In Europe it’s common to use /P to indicate that you are away from a permanent station. In the UK it used to be required but isn’t any longer.
Sometimes they get quite pedantic. To get a Kenya visitor’s licence you have to give an address you’ll be staying at in Kenya, and that becomes your “home” address for the duration of your visit. If you operate anywhere else you’re required both to sign /P or /M (as appropriate) and to give your location as well. At least the licence is clear about it, though.
Same in Singapore and India, though some organizations are flexible if you talk to them. I think they basically want to know where they can reach you locally if needed. LOL in Singapore, Address: Marina Bay Sands Hotel… By the pool…with an adult beverage…and not the antenna.
It really depends on the country. In New Zealand, for example, you don’t need any paperwork and you can operate for up to 90 days using ZL/callsign or callsign/ZL
In South Korea you must apply for a permit. Then you can use HLx/callsign, where x is your region number, or you can request your own Korean (HL) callsign.
In Japan you can only operate under the reciprocal agreement if your country is listed here:
You have to use your host’s callsign and your own callsign, and your host must be present.
Or, you can apply for a reciprocal licence (if your country is listed) by following these instructions: http://jarl.or.jp/English/3_Application/A-3.htm
But I don’t know the format of the issued callsign.
Not quite sure where the irritations would be… but alas, I am trying to understand the exact legalities so that I operate legally within each country. Hence my question. And yes I do operate from many countries.
When I visited Australia back in April there seemed to be some confusion about how visiting amateurs should identify themselves. I eventually settled on M0LEP/VK with additional location information…
