Just notice that we will be swapping SOTAwatch onto a new server this evening.
There may be some downtime shortly but we’ll try and keep this to a minimum.
Apologies for any inconvenience.
73, Jon
GM4ZFZ
73, Jon
GM4ZFZ
In reply to GM4ZFZ:
Test…
In reply to GM4ZFZ:
test squared.
In reply to GM4ZFZ:
Well that certainly is a significant improvement! No longer is there a wait for a large list of summits to load - it was always a pain when I asked for the GM/SS summits, Hi.
Thanks to you Jon and the MT for another improvement.
73, Gerald G4OIG
In reply to G4OIG:
VVVV
RYRYRYRYRYRYRYRYRYRYRYRYRYRYRYRYRYRYRYRYRYRYRYRYRYRY01234567890
MESSAGE ENDS
NNNN
Whoever it is in Bedford with phone number 567890 is going to be upset with all those stuttering messages on his answer phone
Colin
No foxes Andy? looks like a call band in my time
Rob
G4RQj
Activator logs entered are not showing in the browse summits in country lists (e.g. ON) of activated summits as activated by me, but my logs are showing as last activated on the specific summits page (e.g. ON-013). I expect the data may not have migrated across yet to the country page, thought would inform the powers that be (Jon & Andy) in case there is a problem.
73 Phil
In reply to G4OBK:
Hi Phil,
Thanks for reporting this. It is really helpful and if others spot anything please also get in touch.
We did run into one or gnarly issues on the transfer which took quite a while to resolve. So unfortunately there are still a few things to tidy up which I did not manage to address last night. So there may be some reduced functionality for a little while. Your issue is a case in point.
Another example will be the digest that may or may not go out sucessfully tonight depending when we get the chance to look at it.
Another is that posting replies with apostrophes will fail due to ancient code and a PHP setting being wrong. Will try and fix this later as well. Meanwhile remove apostrophes (I had to in this post!).
Thanks for your patience!
73, Jon
In reply to GM4ZFZ:
Two posts that I have made in reply to threads today never appeared. Odd.
73 Richard G3CWI
In reply to G3CWI:
Remove the apostrophes and use a back-tick thus >>>> ` <<<<
In reply to GM4ZFZ:
The last spot via the KU6J RBNGate came July 2nd at 1854z, Jon. Nothing since the server swap.
Elliott, K6EL
I am seeing different SOTA spots on the MMM0FMF SOTA Cluster and SOTAWatch.
FMF Cluster seems to be collecting KU6J RBN and SMS only.
SOTAwatch 2 just collects the spots put in by chasers like me.
I am running both systems side by side so no problem for me hihi!!
Thanks to the MT for the continued technical background work.
73 Phil
In reply to G4OBK:
SOTAWatch.FMF Cluster seems to be collecting KU6J RBN and SMS only.
That’s correct Phil, see Andy’s explanation here:
People who are running my SOTA Spot Monitor software will see all spots, including RBNGate spots, SMS spots and those that people submit to SOTAWatch. Unfortunately the RBN and SMS spots are not making it onto the SOTAWatch web page at the moment. I’m trying to manually re-post to SOTAWatch a few of the RBN spots that I see, but I don’t think I can keep up with the volume!
Anyone who wants to install my SOTA Spot Monitor software can do so via the link below.
Eric KU6J
In reply to KU6J:
Hello Eric,
“…SOTAWatch web page at the moment. I’m trying to manually re-post to SOTAWatch a few of the RBN spots that…”
I have been doing the same, most recently Darius DL/M0KCB/P on DM/HE-003 at 15:31Z. I could not hear him but it was quite nice to hear other chasers who could. Anyway time to take a walk in the forest with Bertie the greyhound. I have not been around much today on the radio (scorchio in SE UK)but bands do not appear to me here in great shape.
Mike
In reply to KU6J:
Yahoo | Mail, Weather, Search, Politics, News, Finance, Sports & Videos
Oops!
You need to be a member to perform this action.
Another group to consider joining, I guess…
Ah well, some folks were muttering about spots and shooting fish in a barrel not that long ago…
73, Rick M0LEP
In reply to M0LEP:
It looks like we should be back in business. Jon has updated a few things and RSS feeds and Spotlite now seem to be working. SMS originated spots are getting to SOTAwatch and web originated spots get to the RSS feed. This should mean that all 3rd party utilites are now functioning again (Sotagoat, RRT, SOTAcluster etc.)
The MT had a discussion about the various web services we have and how we will move forward. Technology never stands still and some of our server technology is getting a little long in the tooth. Jon will be talking more about what will be happening over the coming months.
This little SNAFU is an example of how easy it is for things to grow like Topsy with time and then when something changes, it takes a while for those involved to remember all the subtle nuances of what was done to make it work. This time things weren`t helped by Jon having a very full work calendar and not having the time to sit down uninterrupted to review things.
I can imagine it is all a bit of a nightmare. Even just upgrading your own PC if you run lots of software / apps is a major exercise… a server change with all the extra stuff running based around it must be a massive undertaking I would have thought.
Thanks for all you guys do for us…
Phil
Aye. Been there more than once, and only mostly avoided consequent all-nighters…
Thanks for all the work you folk do.
73, Rick M0LEP
