I visited Japan last year and did a few SOTAs. I will be in Japan again starting this Saturday for a week. I plan on JA/KN-007 and JA/KN-026 this Sunday. The following Saturday, I will try JA/ME-011 and maybe JA/ME-012 depending on the weather.
Last year I made all my contacts with CW. How difficult would it be to do 70cm FM in English? What frequency would I use?
433 is the simplex calling frequency as per the band plan, but find a clear frequency, add a spot and the local chasers will find you. English would then be OK.
I have activated the first two summits you have mentioned on HF (SSB) and I have activated other summits in Japan using 2-meter FM. The national calling frequency for 70 cm in Japan is 433.000 which you may use to notify other HAMs that you are doing a SOTA activation but you will need to announce your activation and quickly ask others to QSY to another frequency. I am pretty sure the 70 cm band will follow the same pattern as the 2-meter band so you may want to consider 433.040, 433.240 or 433.280 as your chosen frequency. Japanese HAMs will all understand numbers in English very well so you are probably safe to get on 433.000 and say “CQ SOTA, CQ SOTA, JS2SBG, please QSY to 433.240” for example. If you notice, other than commonly understood numbers, you are only using one English word in that announcement and I am pretty sure every Japanese HAM will understand the word “Please”. As I am sure you have already experienced, Japanese HAMs will be extremely patient and understanding. I am sure it will be a wonderfully rewarding experience for you to activate by voice.
The Japanese HAMs will strictly adhere the NATO phonetics with the exception that often they will say “Japan” rather then “Juliet”. Speak slowly because your accent in pronouncing everything won’t be intuitive to the listener. When I give my call sign in Japan, I will often use a slight Japanese accent, but tying not to sound too patronizing. If I were to use your call sign, it would sound a bit like “Julietto Siewa Tsu Siewa Bwavo Gawf”. Don’t worry about it and just speak slowly and you will enjoy the experience.
Paul
I activated a few summits, but did not try VHF/UHF. I think my favorite this time was KN-007 with a bowl of miso on top.
As always, thanks for the advice.
