To me the important thing to ask is does the chaser get an (unfair) advantage over other chasers by operating a remote station from the summit. If their home station is in its usual place then there is no advantage from a propagation viewpoint. It is subject to all the limitations of a home station operated by its owner whether s/he is at the shack desk or at their dining table or in the car. So the only benefit gained by the remote operator is that they know the activator is on the air. That’s no different from seeing a self-spot on sotawatch posted by the activator.
If the station operated remotely is located other than at their home station, things are different. On hf there could be a distinct advantage gained if the station has a different antenna and power than their home station normally would. On vhf if the station is located at a better place for vhf operation than their normal home station then they do get an advantage. That advantage could make a contact possible that would otherewise not be possible. Taking an edge case as we say in IT, the location of the station could be parked downhill from the operator, located 1 meter below the border of the AZ while the operator is sitting at the trig point of the summit, which could be 250m away if the slope is 1:10, or 25m (times the sq root of 2) away for a 1:1 slope (I did say an edge case) or 2.5km away if the slope is 100:1. In that silly case, there is a clear advantage gained by that operator over a regular home chaser or in some cases even over an operator on another summit, who is just too far away to make the contact. This contrived situation would be a setup specifically for the summit in question and competes unfairly with regular chasers or activators at other summits. In that kind of case I think it’s obvious that an unfair advantage is gained and they should not be entitled to make that contact, for either their own benefit as a chaser, or for the activator at the summit, to give him/her a vital contact to allow them to claim the points for the summit.
In between the “normal” use of a remotely operated home station and the silly example above, set up purely for that contact to be made, (ie. an artificially close remotely operated station) there are many other different situations for which a case could be made to allow them to contact the activator for the benefit of both the activator and the chaser.
To disallow unfair remote operation the team running the WWFF program in VK decided to disallow remote chasing/hunting, on the basis that operating a station, say in the east of Australia would give the operator a big advantage compared with being located in the far north or far west, or even the far north-west, whatever the “normal” home location was for that operator. So they made a rule that said remote chasing/hunting was not permitted unless the operator was in the same state or territory as the home station, and the home station had to be one that the operator owned. Ie. it was his own home station. I ran into this problem for my home station where I wanted to operate it from an alternative residence about 60 km away by road, but the home station was in New South Wales (VK2) and the remote location was in the Australian Capital Territory (vk1). I took the view that by doing this I was not gaining any advantage over my normal use of my home station. Every other environmental factor was unchanged, no different antenna, radio or station capability.
I then wrote to the management group of WWFF in VK and put the case for allowing my operation even though it technically breached the “same state” rule. This triggered a review of the rule and in due course I believe it will be revised, in the meantime my operation has been approved, which is great because it gives me something to do and allows me to keep up with radio operation even though I have no options for a radio station in the apartment I am living in. At my age (77) with some health issues I still need a hobby activity I can do without always setting out on a hill climb. (This is partly why I activate the drive-up Canberra SOTA summits so often.) I did suggest the rule disallowing remote station chasing/hunting might be better based on a distance than a political and administrative division of the country into states and territories that are vastly different in area. There would be border issues if using states, in some cases the border runs down the middle of a street you might live on. A vk1 on one side and a vk2 on the other. Same in VK2/Vk4. Vk2/Vk3 has a huge river (the Murray) as the border in most of its border towns so the problem is lessened but still the use of a state as the deciding factor is clumsy and just doesn’t work well.
All these factors will be similar if the MT wants to set up scenarios which would be permitted as fair use to make SOTA contacts. It won’t be trivial and will take some discussion and time.
Apologies for long winded comment.
73 Andrew VK1DA/VK2DA
