Registering a client User-Agent for a third-party app using the SOTAwatch3 API (JA spots/alerts, read-only)
Hello SOTA MT and all,
I’m JK1TBL, an amateur radio operator in Japan. I’m developing a small
mobile web app called “Smart HAMLOG” that helps Japanese operators with
logging. As one feature, it shows current SOTA activity (spots and alerts)
for Japan.
I’d like to declare the User-Agent it uses and confirm that our access
pattern is acceptable, in line with your API usage guidance.
How the app uses the API (read-only):
- Endpoints: SOTAwatch3 only (api2.sota.org.uk) — /api/spots/{count}/all
and /api/alerts. We do NOT use the database API (api-db2).
- Scope: results are filtered to the Japan associations (JA, JA5, JA6, JA8)
for display only. No spotting, no posting, no writes of any kind.
- User-Agent: “Smart HAMLOG ” (e.g. “Smart HAMLOG 2026.31.65”),
which includes a version string so you can identify the client.
- Server-side relay + caching: all requests are made by a single
Cloudflare Worker that caches upstream responses (spots ~90 s,
alerts ~300 s). So regardless of how many app users are active at once,
upstream requests are at most roughly one per 90 s (spots) and one per
300 s (alerts). The load on your servers is small and bounded.
- My contact details are below so you can always reach me if anything
looks wrong or if you’d like us to change something.
Could you kindly let me know:
1. Whether I need to register this User-Agent anywhere, or whether a
descriptive User-Agent like the above is sufficient?
2. Whether the usage described (read-only, cached, JA-filtered) is
acceptable as-is, or if you would prefer any adjustments — for example
a lower polling frequency, a different endpoint, or specific attribution?
I want to be a good citizen of the SOTA ecosystem and to follow your
preferences. Thank you very much for maintaining SOTAwatch and the API,
and for all the work behind SOTA.
Hiroshi Yasukawa de JK1TBL
I can tell you haven’t read SOTA API Terms of Service because you haven’t followed all the steps listed therein.
Thank you, I will check it out!
How long have those terms of use been there? (he asks shiftily).
The terms themselves have existed for a while, the docs page for about 4 months.
I love the last paragraph of the terms :laughing:
Google AI is not fooled though.
Most AI coding assistants treat it as prompt injection these days and ignore it, but I’m hoping the next frontier model will scrape it eventually and it’ll land up in the backend.
How, pray tell, does one join the API Consumers Group?
73, Lance . .
Click on Groups in the hamburger menu and it’s listed under there.
