When logging on QRZ for example and you are out portable SOTA/POTA or CQing from a hill etc
How do you log your locator on QRZ?
Do submit your log manually into the correct log book (like I do on QRZ) and then edit the locator square to be the square you are /p from or is there a better way?
That’s what I have done… recently I’ve only been logging on SOTA Database (I have a backlog to catch up with on QRZ - if there’s an easier way I’d be keen to know).
I log on paper on the hill and then enter using FLE exporting ADIF which I upload to SOTA, POTA and Log4OM which uploads to LoTW. As well as the summit and POTA references I also use the correct locator for the summit.
I am not sure it does change for all.
They way I have been doing it (from a POTA export as ADIF import to QRZ)
Import the ADIF into the correct log book /p
The go into each record and the edit, edit the location (IO83kj or what ever) then save the record.
Go to the next and repeat.
