A few weeks ago, I stumbled upon a Chinese version of the good old ultra-simple “Pixie” CW transceiver kit on eBay. It cost $3.56 including shipping and arrived in less than three weeks. Assembly was a breeze; the PCB is of good quality, and no components were missing, although some of the capacitors were quite far off their marked values. However, I did not substitute any of them with my own components. eBay link (there are many other sellers for the same kit):
Not having enough space for a decent 40 m antenna at home, I tried activating a nearby hill today, HB/ZH-012 Aeugsterberg, using only the Pixie, an EFHW antenna (in inverted L configuration), a 12 V battery, a straight key and the earphones from a cheap prepaid cellphone. I also brought a QRP wattmeter to see how much power was actually going out to the antenna. Turns out it was about 350 mW forward and 70 mW reflected (the antenna was a bit too short and not mounted optimally). So definitely QRPp at around 0.3 W.
What can I say… it worked and I’m impressed! 16 QSOs, and reports ranging from 339 to 599, including an S2S with HB9/PB2T/P who needed a lot of patience to get through to me as the HB9/P confused me amid the other stations I was hearing
@PB2T Thanks, Hans!
This Pixie version always transmits at the crystal’s fixed frequency, so QSY = crystal swap. Beside the 7.023 MHz crystal that was included in the kit, I also had one for 7.030 MHz that was easier to work with as the band was more quiet around 7.030. For RX, the crystal gets pulled a bit by a poor man’s varicap diode (1N4001) controlled by a trimmer pot. There is no audio filtering or image suppression, so you hear everything ± 10 kHz from the crystal’s frequency and have to do the filtering in your brain/ears. Before I left home, I tried to adjust the trimmer so that someone transmitting on my TX frequency would end up at around 600 Hz in my headphones, but it turned out to be futile as things were completely different at 3 °C on the summit, and the RX/TX offset also drifted quite a bit. That’s why I asked chasers in the spot to send my own call as well, as it was hard to figure out who was actually calling me and not some other station on a nearby frequency.
Conditions varied quite a bit over the hour that I was QRV; sometimes I was able to copy the chasers quite well amid all the other traffic on 40 m, and sometimes they were barely audible even though I’m sure they would have been a 579 or better on a “real" rig. Several times a strong AM broadcast station faded in and out, so I could listen to the news in English while working chasers ![]()
I hope my fist wasn’t too bad, as I couldn’t hear what I was sending! There is no CW sidetone on the Pixie; you just hear a loud “pop” when you key down.
There are some tweaks for the Pixie to get more audio gain and a narrower bandwidth, which I may try, and a sidetone can also be added of course – the point of this exercise was to see whether it’s possible to activate a summit with such a cheap and minimalistic unmodified rig.
I would like to thank all the chasers with the patience to work me with my weak signal and deaf receiver, and apologize to those who called but couldn’t get through. @SP9AMH asked for 30 m; I have a crystal (at home ;)), but the output LPF and antenna were not suitable for 30 m.
vy 73,
Manuel HB9DQM
