For iOS users looking for a portable FT8 solution, you might want to give this a try. It can call CQ on its own and automatically run the sequence when someone replies—set it and forget it.
It adds about 3 oz to your pack(reduces $30 from your pocket) and frees up your iPhone for more important tasks. More details:
I’d never heard of a Cardputer before but I ordered one last week and successfully (I think) burned your firmware at the weekend. I’m yet to try an activation but the Cardputer ADV and QMX seem to be working.
Thanks for trying it, and thanks for your attention. I googled the ZX Spectrum and learned a bit of its glorious history — good stuff.
I’ve brought DX-FT8 on a few SOTA trips (including Mt. Whitney), and it worked well. I only ran into two issues:
It’s a little bulky (I admit I’m being picky). Not a big deal for a day trip, but on multi-day trips it makes me think twice.
It puts out about 0.5–0.7 W, which is sufficient and fun to play with — but when time is limited, 2–3 W makes it a lot easier to get the job done.
Mini-FT8 is entirely inspired by DX-FT8 (and I made a small contribution to improve its UI). I haven’t brought it to a summit yet, but in a few POTA field runs it worked seamlessly with the QMX, and I was able to log about 10 QSOs in roughly 45 minutes. Mini-FT8 is optimized specifically for QRP portable operation. Also, the device is commercially available and very affordable.
I hope it helps make FT8 more popular among SOTA activators.
Another point: since Mini-FT8 supports free text natively, it could also be used to beacon your location in a distressed situation—useful if a SOTA operator doesn’t have (or forgot) an InReach. It’s not a substitute for dedicated emergency gear, but it can add a little extra safety margin, just in case.
The project is open source, and the UI interface was entirely generated by ChatGPT (Codex) based on my instructions, so keyboard re-mapping should be straightforward. If you can compile the code and provide the re-mapping table to ChatGPT, it can update the code for you. I probably won’t do it myself, but I’m happy to answer questions.
Just flashed 2.0 to my Cardputer ADV. Such a great little piece of software and thank you for adding KH1 support!
One thing I noticed though is it doesn’t like the GNSS/LORA hat. I was hoping to use this for the GPS requirement. Once you plug it in to the Cardputer Adv, it makes the screen glitch and Mini-FT8 becomes unusable. Same if you plug it in while the Cardputer is powered off.
Just thought to report it in case there is a bug there or if the hat is just incompatible? Thanks for the great work and for sharing it with the community.
N.B.: I’ve reported it as an issue on your Github too. Just in case.
Got the GPS module, but my KH1 is away at the minute. Once it’s back I’ll finish this off and give it a test drive. Just to confirm, the GPS/GNSS/LoRa Hat that most folks may have doesn’t work with the software. I was able to confirm this once that recommended GPS module arrived. Using the HAT throws it in to a tizz. Remove the HAT, add the module. Disco.
Also, if anyone is keen, the new Cardputer Zero launches today at 9am EDT (2pm BST/IST).
Someone posted a comparison image as well for the Cardputer ADV and Zero. I think it is basically a Cardputer ADV but with a Pi CM4 under the hood (not a CM5?).
Same! Well, at least I hope M5 Stack keep their promise with the reservation spots. I’m going to stick with the ADV for the KH1 and QMX for now, but would like to look in to using the Zero to work with some additional modules I purchased recently.
Mostly CW-related ideas but some other stuff too I’d like to try out, perhaps a mini Linux device. Possibly some emulated (greatest computer of all-time in my opinion) Commodore 64 amateur radio ideas!
I reckon @M1BUU is already dreaming up some fun stuff for the Cardputer!
EDIT: It went live there at 2pm BST/IST. Looks like they are at €200,000 raised in 9 minutes (€230k in 13 mins and rising). Mind blowing. I went for the full fat Zero and both caps as the LoRa and GNSS / NFC caps appear to not be all in one caps this time round.
Just an update if anyone is interested, I finally got to test out FT8 on the KH1 yesterday. The photo below shows a bit of cable spaghetti but really it is just stuff strewn around for testing.
I can use shorter cables to sort that out. If you prefer to use the GPS 1.1 module, you can use a SandwichC module to add a GPS 1.1 and a Chain Bus module together to save having modules flapping about everywhere.
Here’s a couple of snaps, first of the KH1 in FT8 action and another demonstrating the Sandwich module.
