PrTrx PT1 Transceiver
Has anyone seen this radio? 10W
From HamGeek: $239.00 (£182.52)
From AliExpress (£480.59!!)
Features:
* High-Performance SDR Architecture
* Rugged and Compact Design
* 2.0-Inch Color LCD Display
* 28kHz Spectrum and Waterfall Display
* All-Mode Transmit and Receive Across All Amateur Radio Bands Within 3.5-29.7MHz
* Continuous-Frequency All-Mode Reception Across 3.5-30MHz
* JNR Digital Noise Reduction Technology
* Supports Amateur Radio Data Communications
* Supports Computer Connectivity and Control
Specifications:
* Transmit Frequency: 3.5-3.9MHz, 7-7.2MHz, 10.1-10.15MHz, 14-14.35MHz, 18.068-18.168MHz, 21-21.45MHz, 24.89-24.99MHz, 28-29.7MHz
* Receive Frequency: 3.5-30MHz
* Operating Modes: LSB, USB, CWL, CWU, DGL, DGU, AM, NFM
* Frequency Steps: 10Hz, 100Hz, 1kHz, 10kHz, 100kHz
* Receive Sensitivity (SSB/CW): Better Than 0.20μV (-121dBm) at BW: 2.4kHz/500Hz
* Receive Sensitivity (AM): Better Than 0.4μV (-115dBm) at BW: 6kHz
* Receive Sensitivity (NFM): Better Than 0.4μV (-115dBm)
* MDS: Better Than 0.035μV (-136dBm) at CW BW: 500Hz
* Side-band Suppression: Better Than -50dBc
* Filter Bandwidth (SSB): 2kHz, 2.2kHz, 2.4kHz, 2.6kHz, 2.8kHz
* Filter Bandwidth (CW): 50Hz, 100Hz, 200Hz, 300Hz, 500Hz
* Filter Bandwidth (AM): 6kHz, 10kHz
* Filter Bandwidth (FM): 11kHz
* Output Power: 0.1-5W ±1dB (Up to 10W ±1dB With Enhanced Cooling), Continuously Adjustable
* Frequency Stability: ±1ppm (After 30 Minutes of Warm-Up)
* Spurious Emissions: Better Than -50dBc (2nd and 3rd Harmonics)
* Carrier Suppression: Better Than -50dBc
* Antenna Impedance: 50Ω
* Microphone Impedance: 2kΩ
* Audio Output Power: 1W at 8Ω; 2W at 4Ω (≤10% THD)
* Operating Voltage: 11-15V DC (13.8V Typical)
* Power Consumption (Receive): ≤280mA at Minimum Volume
* Power Consumption (Transmit): ≤2.5A at 10W, 50Ω Load (Maximum)
* Operating Temperature: 0°C to 50°C
* Dimensions: 116mm x 87mm x 48mm (L x W x H, Excluding Protrusions)
* Weight: Approx. 0.38kg (PT1 Main Unit Only)
